Hey everyone, I was wondering if there are any distributed computing projects that might help cure diabetes because my dad has it.
Thanks,
hotwaxisbad
Thanks,
hotwaxisbad
I would support it!!!
I got diabetes type one this ester (4 shot a day)
Does a specific project of WCG that would aid the cause?
anyone know if there is a DC project for diabetes?
If there was I'd actually start running a DC program again.
Type 1 diabetic here
Q6600 G0 [3.6ghz 9x400 1.31v] ~ Thermalright Ultra120E ~ Gigabyte EP45 UD3R ~ 4x1gb Crucial Ballistix Tracers [800mhz 4-4-4-12 2.2v]
HiS ATI Radeon HD5850 1GB [850/1125] ~ 22" Dell 2209WA eIPS [1680x1050 at 76hz]
80gb Intel X25m G2 [Windows 7 Pro x64] ~ 2 x Seagate 500gb 7200.12 [Raid-0] ~ WD 1TB Green WD10EARS [Storage] ~ Corsair HX520 in an Antec 900
E2220 2.4ghz ~ BFG 8800gt w/ Coolink Gfxchilla ~ Asus G31 P5KPL-VM ~ 4GB GSkill PQ DDR2 800 ~ Seagate 500gb 7200.11 [Windows 7 Pro x64] ~ Antec EA430D ~ Antec SLK3700BQE
Hi friends, recently I have found out that my cholesterol is slightly high (220). The doctor said to exercise and eat healthy. What range of cholesterol is acceptable daily in a diet if you are trying to lower your cholesterol? I know that wholegrain and oatmeal are supposed to help lower it, are there any other foods or steps that work?
wow .. 220 is borderline ..
maybe you could cut down diary and try 1 day plain oatmeal diet?
exercising .... most guys like weight lifting coz it shows the muscles .. so why not make it one of your vision to built the body?
if it's bout lowering high blood levels it is possible which .. you could try by taking celery (vege)
if you cant stand the smell, boil it and drink the water
measure the blood levels before and after ..
if you have normal blood pressure ... the measurements should give you low blood pressure ..
