Those who saw this thread
http://www.xtremesystems.org/forums/...d.php?t=204029
would've known that I was retesting for leaks after finding some spider cracks on the full face EK block.
The thread soon turned into a "your card is bent" chit chat
As fate would have it, the card block leaked shortly after the test and killed the gfx card
I had the case on its side after the leak test (on hindsight, that was a bad idea) so the water wicked itself between the card and the block. No prize for guessing wat happened.
Here's shots of the cracks...which was also the point of tension (causing the bend) as well as the site of leakage
Apologies for the poor image as it's really hard to get a clear shot that close up. The 2 holes i'm tryng to focus on in these 2 pics had the largest cracks but I just can't seemed to get the right angle to show them properly
To make matter worse, there're no more identical cards on the local market (the non-reference cards of identical specs would not accept this block) and honestly, I wouldn't trust this FC block enough to put it on another card again anyway. It is now an expensive paper weight
I find 2 problems that EK should mull over:
1. The bending issue
2. The spider cracks around the screws (and leakage) for their acrylic covers
To quote from another regular here
"Burn me once, shame on you. Burn me twice, shame on me."
I'm staying clear of FC blocks from now on as I have a 3rd issue with FC blocks (nothing to do with EK) and thats compatibility, even amongst identical card models. I know this is a DUH and everyone knows that (and treats it as a necessary evil during upgrades), but not many would consider this particular scenario, where the existing card dies and the block is not able to fit replacements of the same model. That feeling sux
coolmiester had identical issues
http://www.xtremesystems.org/forums/...48&postcount=1
To those on such blocks, I would urge you to shine a light through it once in awhile to check for those insidious cracks and to also not overtighten the block (although I've also read someone with super high temps due to undertightening )
Well...I'm gonna grab a Dtek V2 GPU and some enzotech sinks...hopefully I'll get the beast up and running soon again
