How do you read the vcore accurately? Without using the ageis panel. I've tried speedfan, everest, and cpuz without any luck. Keeps coming back at around .8-.9v, which I know isn't right!
The new ageis panel reads the vcore correct to me - ver 1.0.2.34
Yes, Aegis Panel and Everest read the same numbers. I think thats correct.
Regards LordIT
Board: Foxconn Mars, BIOS G30
CPU: C2D E4400 2x2,0Ghz (200x10) 1,32V @2,0Ghz(200x10) @1,06V(ratio 10) @0,92V(ratio 6)
Cooler: Xigmatek HDT-S983
RAM: 2 x 1 GB Cell Shock CS2110650, D9GMH, @Mushkin XP2-8500 @800Mhz (1:4e ) @1,92V @4-4-4-8 @Performance Level 2
Power: BE Quiet Straight Power 600W
HDD: 2x Samsung HD403LJ 400 GB SATA-II, AHCI
Grafics: PowerColor 512MB X1950Pro Extreme PCIe
Burner: Pioneer DVR-212
Case: Aerocool AeroEngine JR
OS: XP Professional Edition x64 SP2
NCspec, maybe it helps if you mention what motherboard you're using.
Ryan the same goes for you.
I have a blackops and I can tell you, so far I haven't found any program that reads it correctly. I just look it up in the bios if I need to know it
Seems to be a voltage fluctuate.
I think it's normal.
Mobo: Foxconn MARS
Cpu: Wolfdale E8200 C0 @ 4ghz @1.38v w/ TRUE-120 Black
GFX: 8800GT G92 @stock
Memory: Team Extreem 2x1 5-5-5-15 1100ghz @2.11v
Hard Drive: SB 500GB
Optical Drive: LG 22x DVD/RW LS
Case: Lian-Li PC-G7B
Foxconn ROCKS!
bios & DMM what board ?
[SIGPIC][/SIGPIC]
PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
FOXCONN MARS
COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
Quattro 1000W
Radeon 2-4850's in crossfire
OCZ Vertex SSD thanks Tony!
ALL PIPED INTO HOUSE AIRCOND ;}
*QUANTUM FORCE* saaya & sham rocks !
*REAL TEMP*
At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
*MEMSET* Felix rocks !
*SUPER TEC MAN* UncleJimbo rocks !
OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
sorry. Blackops. Everest reads .98v for me. Ageis panel reads the bios voltage, which in the bios says its lower..actually Ageis panel reads higher than what I set in the bios! I don't have the vdroop compensation enabled either.
If i have 1.4 in the bios, ageis panel says the exact same.... However with some voltages the 'actual' voltage in the bios is about .125 or around that less then target voltage if that makes sense... I have blackops, and assumed ncsepc did too.....
mhhh how much higher does aegis panel read than what you set NCspecV81?
can you post a screenshot?
aegis panel is very accurate with reading voltages, IF it works properly
its still a bit buggy, then again dont forget its less than 1 year old ^^
ryan, yeah, it tends to dip a bit lower depending on the cpu used and the load.
thats normal
For me - AEGIS, CPU-Z (for vcore) and Everest read the same temps. I think that AEGIS panel is pretty accurate but I'll check this week with DMM.
MBO Gigabyte P67-UD4-B3 // CPU Intel i5 2500k //
GPU Gigabyte GTX470 // PSU Corsair TX650W //
RAM 2*2GB Geil Black Dragon + 2*2GB Corsair DominatorGT // HDD WD 640GB + Seagate 250GB (410AS)
Everest is completely buggy with your BlackOps. The voltages vCore, vdimm,... are much too low.
vDIMM = 1,27 V is fantastic!
Have you already tried Everest 4.50.xx?
Aegis Panel reads correctly. The BIOS vCore conforms to the adjusted in Aegis Panel. The measured vCore is a bit higher. Thats normal -the same with the Mars.
Regards LordIT
yes, please try the latest version of everest and let me know if its still not reading vcore correctly
mhhh ok, let me get in touch with everest then
