Erm...most of the people in this thread
In fact, most of the top scores not done on 4GHz quads or Harpertown systems
Rig specs
CPU: i7 5960X Mobo: Asus X99 Deluxe RAM: 4x4GB G.Skill DDR4-2400 CAS-15 VGA: 2x eVGA GTX680 Superclock PSU: Corsair AX1200
Foundational Falsehoods of Creationism
Do you always work so hard to prove your points? No need to, really.
Guess you're right, something's off. Mainrig in sig does "only" 30,200 (with 24/7 settings and 1,5 weeks uptime tho...).
Should be more compared to some x86 scores.
Lol, little bit of quoting never hurt anyone
And yeah, compare your 4.1GHz Kentsfield with 4GB of DDR2-1100 to Post #16 - 3.7 Kentsfield with half the RAM operating at a lower speed gets 3k more - because it's running in x86 mode.
Rig specs
on the techpowerup thread they created a version that forces x86 mode even on 64 bit systems.
Seeing as you haven't tried the Harpertown on an x86 OS, we have no idea It'll be difficult to find one that supports eight cores properly, though, so the point is rather moot.
Rig specs
XP Pro should do it.. no?
I'm not gonna reinstall for the sake of a benchmark though
I can't find it. Link?
* Lian Li PC-B10 * Phenom II 1090T @ 4GHz, NB @ 3GHz * ASUS Crosshair IV * G.Skill Flare PC3-16000 4x2048MB * 4xOCZ Vertex2 RAID0 * LSI 9260-4i * Dell U2711 Ultrasharp * KFA2 GeForce GTX 580 1,5GB *
* Asus Xonar Essence STX * LG CH10 10x Blu-ray * Windows 7 x64 Ultimate SP1 * QNAP TS-459 PRO, 4x1,5TB Seagate RAID5 *
Man I'm so lazy. I wanted to release a 32-bit locked version but never did.
Particle's First Rule of Online Technical Discussion:
As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
Rule 1A:
Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
Rule 2:
When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
Rule 2A:
When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
Rule 3:
When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
Random Tip o' the Whatever
You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
Here's an x86 locked version straight from my compiler. It also shows the relative performance of each thread.
Rule 1A:
Rule 2:
Rule 2A:
Rule 3:
Here is the result in XP x64 and Vista x64 respectively. A very nice gain from a simple switch to x86.
Asus Maximus Formula (Rampage Conversion Bios 0403)
Q6600 G0 stepping@4.05 Ghz
8GB G. Skill 1066 @ 1081 Mhz
EVGA 280 GTX
Auzentech Prelude
2X 74 GB WD Raptors in Raid 0 Windows 7 Ultimate 64
2X 1 TB WD Caviar Blacks in Raid 0 Vista Ultimate x64
Thermaltake Toughpower 1200W
DTek Fuzion V2 in a custom CPU only water loop
Coolermaster Stacker 830
Hanns-G 28" widescreen
Klipsh Pro-Media 2.1
G15 Keyboard and G9 Laser Mouse
Thanks particle, maybe I'll run it later tonight to see how big the differences are. Next goal should be a proper 64bit version
Pardon that, I flopped them. Vista got worse results, but at the same time, my xp is running barebones and Vista was with everything running in the background. I would say that they are actually fairly similar. The difference is probably in that last two percent of core 1 you see going to run the OS during the test and in test to test variation.
EVGA 280 GTX
Auzentech Prelude
i recently reinstalling windows xp and i ran the test on a clean installation and no performance difference from before. and with using the amd fusion program to turn off processes whenever i want i didn't see a change either. but the amd program gave a more consistant score. usualy my score will range around 40 kcus but with fusion on it will stay about the same with a range of about 5-10.
Some more Mhz + x86 mode bench = ridiculous speed
a little overclocking
AMD 1090T@4.0ghz
Enzotech sapphire/Mo-Ra extreme rad
Asus Crosshair IV Formula
ht 2400mhz / nb 2400mhz
12gb Gskill 1300mhz
HIS HD5970
Enermax Evo Galaxy 1250
case: XCLIO A380PLUS-BK
4.61ghz water
4.5ghz superpi 1M 15.585
http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
Phenom 2 125w 965 test results
http://futuremark.yougamers.com/foru...d.php?t=117414
Phenom 2 140w 965 test results
http://futuremark.yougamers.com/foru...d.php?t=109214
Phenom 2 AM2+ 940 cold air results
http://futuremark.yougamers.com/foru...ad.php?t=97430
If I dont get every single drop out of my cpu I feel like someone is stealing from me
Sure it's possible. Just give me a pair of X5460 or 5470.. need higher mult
CPUs are only at 1,27V Vcore, nowhere near max frequency. Only the bus is maxed out
CPU-Z always misread Harpers, my E5420's show a similar number. Clovertowns as well, dunno. Just not optimized for server-grade hardware I guess.
Everest shows the correct Vcore, however.
i saw bad readings on some X2s as well.
http://forums.techpowerup.com/attach...6&d=1224657297
Q9550 @ 4.1Ghz, 2x2GB G.Skills 8500s @ 1160MHZ, Vista x64, utorrent downloading in background.
I don't like since it hogs the resources. I would've loved to inspect how it uses memory, e.g. CPU cache accces, hit/miss rates, branch success rates, retired instructions, DRAM access etc. :|
10K KCU's with 2.4GHz Athlon64 X2.
