Hi, i'm currently setting up 2 loops, one will have ek-supreme, thermochill pa120.0, ek-nb s-max. The other one will have 2 x ek-fc4870, swiftech mcr220 and both will have an ek res and using 1/2" tubing.
I have 2 pumps, mcp355 and mcp655 and i'm wondering which pump to use with which loop. I've heard that the ek-supreme waterblock is a bit restrictive so i'm wondering if i should use the mcp655 or will that be overkill? and instead use it for the 2 gpus.
