+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 39
Thread: Game Skips Real BAD - HELP!!
    Jul 2002
    0
    I have the following setup:
    AMD T-bird 1.33 Ghz
    Thermalright SLK-800 + Tornado 80 mm Fan
    Hercules GeForce 3 Regular
    Abit KG7 Motherboard
    512 Crucial DDr Ram PC2100
    Western Digital 7200 60 Gig
    Windows 2000
    Every time I try to run Counter-strike, it skips ever like 5 to 7 seconds like an FPS spat. I've tried different detonators, different bios settings, and all sorts of things and still cannot stop it. What can I do to fix this?!?
    JBELL
    Guest
    have you gotten new via drivers? for chipset
    Jul 2002
    0
    yes, i just formatted and have the 4.37s
    stoopid
    Guest
    Check IRQ assignments, maybe even disable ACPI and set the computer type to standard in device manager.
    Jul 2002
    0
    It is already set to Standard PC. I did that when I first formatted.
    Xtreme Member Neptune5k's Avatar
    Jun 2002
    Indiana
    0
    Okay, I've seen this happen with KG7 users in the past and it ususally boils down to a driver issue.
    You have to realize that the KG7 is a hybrid board which utilizes an AMD northbridge and VIA Southbridge. Because of this, you can't just use the VIA 4-in-1 drivers. You have to install the AMD AGP driver pack, for the northbridge, and then you have to install the 4-in-1's excluding the AGP driver, for the southbridge.
    Hope this helps.
    A CPU Cycle is a Terrible Thing to Waste....
    boughetto overclocker sysfailur's Avatar
    Jun 2002
    NORAD Command Center
    0
    Reinstall Half-life and CS. Also perhaps a nice defrag would help. I've had LOTS of problems w/ HL over the years, and a nice clean install always fixes it
    Dinosaurs are chortling.
    i7 930 @ ???, Rampage III Extreme, 12GB G.Skill PC2000, BFG 260GTXOC, PNY Quadro 380FX
    (1) HP LP2475w 24", (2) Dell 2007WFP 20", (6) 1TB Hitachi 32mb, 3Ware 9650SE Raid, Lian Li PC1200B + Custom WC, PCP&Cooling 750w Silencer.
    Jul 2002
    0
    So Neptune:
    I download the AMD AGP Driver from amd.com as well as that via 4.37s. Run the install for the AGP Driver, then run the 4in1s but uncheck the AGP Driver that is included with it?
    Is this corrrect?
    Also, do I need to format again to do this properly or can i just overwrite it?
    Jul 2002
    0
    Also, any recommendations on bios settings for my AGP?
    Right now I am sure that I need AGP 4x.
    But what about:
    Video BIOS Shadow, AGP Fast Writes, AGP Aperature Size, AGP ISA Aliasing, AGP Always Compensate.
    Not too sure about those settings. Which would give me the best performance?
    Evil Kitty mdzcpa's Avatar
    Jun 2002
    Detroit, MI
    1
    Correct. You can download the WIN 2k AGP driver from HERE .
    Just unistall the current 4in1's first (by running the 4in1 install and choosing "uninstall"). Then install the AMD AGP and 4in1 again.
    Hope you don't mind me steppin in to help
    3960X @ 5.1Ghz
    Asus Rampage IV Extreme 1005
    32GB (8 x 4) Gskill Ripjaw Z @2133
    Asus HD 7970 x 2 Crossfire
    OS & Apps: Crucial M4 256GB
    Games: Crucial M4 512GB
    TV & Video: 300G Raptor
    Storage: WD Black 2TB
    Corsair AX1200
    Corsair 800D
    CPU/Video/Mobo Koolance Water Cooled
    Jun 2002
    Detroit, MI
    1
    But what about:
    I like these settings:
    video bios shadow disabled
    Starting with AGP Secondary Lat Timer-
    Secondary Lat Timer : 20h
    Fast Writes : enabled
    4X
    Enabled
    Disabled
    Enabled
    2
    0
    And some good mem settings:
    Manual
    16
    8
    8
    2
    6
    2
    1
    2
    2
    2
    And these AGP Driving Valuessettings under Advanced Chipset Features can help-
    manual
    D8
    slow
    slow
    FF
    Fast
    Fast
    Most of these settings are tried and true by various overclockers.
    These will help
    3960X @ 5.1Ghz
    Corsair AX1200
    Corsair 800D
    Jul 2002
    0
    Ok, well I uninstaleld the 4in1s then installing the AGP Driver followed by the 4.37s without the agp driver. I also did all of those bios tweaks, and after all that, it STILL does it. I even moved my computer out of the cubby it was in in my desk to give it some more air, but that obviously did not help. I am so frustrated. : (
    Jun 2002
    Detroit, MI
    1
    If it's only happening in CS, I'd try a fresh install of CS (as someone above suggested).
    3960X @ 5.1Ghz
    Corsair AX1200
    Corsair 800D
    Jul 2002
    0
    I just formatted yesterday, and sometimes I can feel it in my IRC, so I don't think its only in CS.
    Jun 2002
    Detroit, MI
    1
    If you had a KG7 RAID I'd suspect a bad Highpoint driver/BIOS combination which can cause stuttering and skipping...but I guess it can't be that.
    Are you running anything else in the backgound?
    Using a video tweak proggy (NVMax, riva tuner, etc)?
    3960X @ 5.1Ghz
    Corsair AX1200
    Corsair 800D
    Jul 2002
    0
    No, RivaTuner wouldnt work for me & I already ran CS with & without NVMax, and it still does it.
    And whats wierd is now sometimes it skips, then other times it doesnt. REALLY wierd
    Jun 2002
    Indiana
    0
    So Neptune:
    Is this corrrect?
    You got it You shouldn't have to reformat, just run the VIA 4-in-1 install and use the Uninstall function. Then reinstall the drivers accordingly.
  18. #18
    Xtreme Member septimus's Avatar
    Jun 2002
    0
    Are you running the Hercules drivers or are you running the nvidia reference drivers? I found that I got alot of stuttering, especially in neverwinter nights, with the ref drivers but it cleared away when I installed the hercules-made dets. go to www.hercules.com and have a look...
  19. #19
    Jul 2002
    0
    Well, I tried the whole Hercules thing and that didnt work.
    Someone told me I should remount my CPU to the socket. Could it be possible that I have too much thermal compund on there & that be messing something up? I just recently installed a fan so thats why im wondering.
  20. #20
    Jun 2002
    Detroit, MI
    1
    Doubtful but possible I suppose. What are your CPU temps?
    3960X @ 5.1Ghz
    Corsair AX1200
    Corsair 800D
  21. #21
    Jun 2002
    0
    Just curious, but what sort of activity do you see on your HDD just before, during, and after the freeze/stutter-ings of your games?
  22. #22
    Jul 2002
    0
    CPU Temps are nothing out of the ordinary.
    Like 35 deg. Celsius for CPU & System.
    And no, I don't notice any HDD activicty when the skipping occurs, so I don't think its the HDD.
    Another wierd thing that was when I was at this lan, it didn't do it, but when I get home, it does it.
  23. #23
    Jul 2002
    0
    Ethernet controller problem? Josh, go try it in the game by hosting a game.. so that its a lan connection.. buy a gun.. and run around and shoot it and so forth .. see if it skips...
    let me know
    Jere
  24. #24
    Jun 2002
    0
    Well, I asked about the HDD activity since, pre-hercules drivers, in neverwinter nights the HDD would start to access and the HDD would go solid for a full 3 seconds or more and at this time the game does not respond.
    Since you say that it works fine in another physical location (the LAN) I am thinking you might have some kind of power problem in your house... Is your computer on the same circuit as say a motor or heating element?
  25. #25
    Jul 2002
    0
    Well, I created a LAN game, and it still did it.
    I have my comp sharing on a surge protector with other :banana::banana::banana::banana:, like monitor, speakers, etc. Dunno if that could be the problem.
+ Reply to Thread
