got that same error the first time i ran it - after installing the newest dx redistributable (august 08) everything worked fine.
1. Asus P5Q-E / Intel Core 2 Quad Q9550 @~3612 MHz (8,5x425) / 2x2GB OCZ Platinum XTC (PC2-8000U, CL5) / EVGA GeForce GTX 570 / Crucial M4 128GB, WD Caviar Blue 640GB, WD Caviar SE16 320GB, WD Caviar SE 160GB / be quiet! Dark Power Pro P7 550W / Thermaltake Tsunami VA3000BWA / LG L227WT / Teufel Concept E Magnum 5.1 // SysProfile
2. Asus A8N-SLI / AMD Athlon 64 4000+ @~2640 MHz (12x220) / 1024 MB Corsair CMX TwinX 3200C2, 2.5-3-3-6 1T / Club3D GeForce 7800GT @463/1120 MHz / Crucial M4 64GB, Hitachi Deskstar 40GB / be quiet! Blackline P5 470W
here is my run..i would like to note that i am having major issues in this copy of windows (stability etc). So im not sure whether this score represents the gpu correctly. i will do some good testing later on (about to install vista now)
Intel Q6600 @ 3.6GHz
Asus Blitz Formula SE
OCZ ReaperX PC6400 2x2GB
Sapphire HD4870x2
X-Fi Elite Pro 7.1 & Logitech Z5500
Samsung Spinpoint T166 500GB
Samsung 226BW
Zalman ZM1000-HP
Watercooling
Loop 1: DDC3.2 (XSPC Restop), Fuzion v2, BIGTX360 (6x S-Flex F)
Loop 2: DDC3.2 (XSPC Restop), EK 4870x2, TFC X360 (3x S-Flex F)
Loop 3: to come
[DarthBeavis] "I am gonna try to mod one of these into my wife so can get an early warning of when she gets angry . . ."
Just a pointer to those using the 4870x2.
When i first did the test i got 950 score which seems quite poor compared to other gpu testing in this thread. It turns out that this benchmarking does NOT increase the gpu clocks from 507mhz to 750. So you have to do that manually via CCC first and then run it again
Sapphire HD4870x2
Samsung 226BW
Zalman ZM1000-HP
Watercooling
Loop 3: to come
After tweaking my Vista64 properly i got a slightly higher score than in XP
next up, overclocking the 4870x2
Sapphire HD4870x2
Samsung 226BW
Zalman ZM1000-HP
Watercooling
Loop 3: to come
Hey,
1280x1024 DX9 full screen bench as requested:
Specs:
E8400 @ 3.6GHz,
ATI 4870 @ 830 core / 1100 mem
OS: Windows Server 2008 Standard 32bit
Result is : 1305 points
If anybody is getting the DLL file error, and just wants to find the file on the net somewheres. Just add the file into the WINDOWS/system32 folder. This is for XP users. Anyways heres my bench. All stock settings. Is this a decent score for my setup?
:SYSTEM:
MSI 770T-C45
AMD Phenom ii X4 940 (OC 3.6GHZ)
Corsair H100 closed-loop CPU water cooler
8GB DDR2 memory
2 X Western Digital Caviar SE WD1600JS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive (RAID 0)
Nvidia GTX 460 1GB
CoolerMaster HAF932
jmke, well first let me say hello... I hope all is well over at Madshrimps.
2nd, I must tell you that this is a beautiful benchmark. I like the scenery and the whole layout in general. I even really enjoyed the music that accompany's Tropics. Really nice....
Now here is the score from my single little 260GTX..
It's all good here.........
I see a few runs where people have ran at different settings. you will have to establish one universal setting for the bot but, i think you have a real winner
here
This was ran at my cpu daily clock but the vid card was just slightly higher than daily clocks......
WZ
i've seen quite some anomalies when running the benchmark in window mode. fps are jumping quite often (from abnormally low to high) - my results in window mode were kinda useless. did someone else notice smth like that?
i just noticed that this benchmark will not use the second gpu on my 4870x2 whatsoever :S
2nd gpu load stays at 0% throughout the test
Sapphire HD4870x2
Samsung 226BW
Zalman ZM1000-HP
Watercooling
Loop 3: to come
try naming to 3dmark03.exe
It keeps using my 8800GTS on me, wont let me select my 4870X2.
All along the watchtower the watchmen watch the eternal return.
Well I was playing with this morning with a new vid driver. it went well... I also showed my 260GTX temps on the run. Even at these high clocks and the pressure put on it,
it keeps it's cool...
This is the post test cool down. As you can see it cools back down quite quickly.
I have broke 1600 on this test but, I wanted to show temps and recovery time for temps.
you'll note the only difference between this run and the one above is a different driver and a bump in memory speed.
WZ
Incorrect.
I'm running a full release of XP-64, no .net 2.0 by default. XP-SP2 also does not include it by default as .net was released significantly after.
Now to try and fix rivatuner since updating from 2.10 to 2.11 seems to have broken my ability to overclock my 8800GTS... odd.
still cannot run this bench, quite dissapointing actually.
Sapphire HD4870x2
Samsung 226BW
Zalman ZM1000-HP
Watercooling
Loop 3: to come
Specs in sig...
- ASUS P5E (BIOS 1201+Microcode Update) 400 FSB - Intel E8500@3.8GHZ (1.28750 VCORE) - Thermalright HR120 Extreme - 8GB Corsair PC28500CS (1066 3:4) - 2*2TB Samsung -
- EVGA GTX580 3GB - PCP&C 750W - Antec P-182SE - Plextor PX-760A - Plextor PX-W5224A - Samsung 245T - Razer Mamba - Razer Black Widow Ultimate - Razer Megalodon -
it say I don't have dx10 wrapper I'm on vista 64 ultimate ? lol
Sapphire HD4870x2
Samsung 226BW
Zalman ZM1000-HP
Watercooling
Loop 3: to come
crossfire only started when it was in full screen on mine :/ I've got net 2.0 on it and I still can't use Dx10 on it >_< reinstalling odsen't change it either.
nice bench tool
here's mine with the ultra voltmoded rock solid clocks I play all games on VISTA ULTIMATE SP1 64bits
Cheers
Sergio
Intel Core i9-7980XE@ 4.8GHz 18C/18TH (Direct Die Contact)
ASRock X299 OC Formula
ADATA XPG SPECTRIX D80 (4x8GB) DDR4-3800C17 B-Die
1x Intel Optane SSD 905P 480GB
4x HP EX950 NVMe 2TB on ASRock ULTRA M.2 CARD
EVGA RTX 2080TI KINGPIN 2190/8000 Stock Cooling AIO 240
SilverStone ST1500W-TI TITANIUM
Alphacool Custom Water Cooling
