+ Reply to Thread
Results 1 to 3 of 3
Thread: Core stuck at 53C
    Registered User negev's Avatar
    Aug 2008
    UK
    0
    Core stuck at 53C
    I'm currently blending my Q9450 at 3.33ghz and I've just noticed that core 3 is stuck at 53C.
    A quick google shows this is fairly common, but does anyone know a way to un-stick the sensor? It used to work fine..
    Foxconn Blackops G32
    Q9450 @ 3.4GHz (425x8)
    2x2GB G Skill PI 1700Mhz @ 8-8-8-22
    3TB storage
    RAAAAAAAAA!!!!!!
    Xtreme Addict Xello's Avatar
    Mar 2008
    UK
    0
    According to what program? Have you tried Aegis Panel.
    TJ07 | Corsair HX1000W | Gigabyte EX58 Extreme | i7 950 @ 4.4ghz | Ek Supreme | Thermochill PA 120.3 | Laing DDC 12v w/ mod plexi top | 3x2gb Corsair XMS3 1600mhz | GTX 580 | Raid 0 300gb Velociraptor x 2 | Razer Lachesis & Lycosa | Win7 HP x64 | fluffy dice.
    Aug 2008
    UK
    0
    Realtemp and HWMonitor, Aegis doesn't show the core temps.
    But actually, since I've rebooted it's now working
    I've finally managed to break the 3.2ghz barrier, loving my new PI stix 3.33ghz is now 12hrs prime stable, my brother is coming over tonight so will probably be gaming but in a few days i hope to have it higher..
    3TB storage
    RAAAAAAAAA!!!!!!
+ Reply to Thread
