So I apologize in advance for my work log. This project is time limited, if you didnt get it from the name I have to finish this this week so that I can go back to the school at UW for my second year.
Anyway project is mostly from used items that I picked up, IE used MM-UFO older solid style, I bought all of my radiators used, expect for the thermochill I had that from my last mm case.
One goal in this build was not to drill ANY holes, look at my ingenious pump mounts.
LIST:
CASE:
MM-UFO brushed aluminum older style not hyper modular -used
Radiators:
Thermochill PA120.2 -I had this
HW labs double BIEII? -used
HW labs singe BIE? -used
HW labs Singe BIP?-used
Swiftech mcp120 -used
PUMPS:
Swiftech mcp350 w/oclabs top
Swiftech mcp355 w/aphla whatever top
I bought another used mcp355 that was covered in glue and leaked I tried to fix it and well, look down at the pics and you will see what happened to it.
BLOCKS:
mcw60
mcw30 -used
dtek fuzion v1 w/backplate
BARBS:
all 1/2 - mostly all used, but I replaced used orings
TUBING:
tygon r-3400 7/16id
4 red cold cathodes w/soon to have sleeved/heatshrinked powersupplies
maybe 2 uv cc over motherboard, to accent.
MM fan harddrive rack -red
10 Yate loon 120mm SM -I got one spare (maybe I will make it into ram cooler)
HARDWARE -mostly all used from last build,except new processor
500gb samsung spinpoint
150gb raptor w/window
DFI p35-2r Lt one, whatever its called
e8600 -new! -shooting for 4.5+
4gb 1066 patriot ram - just got the rma back for 2gb of it for the second time, hopefully now it will work - I hate Patriot :/
Voltmodded 8800gt, this is very ugly looking, I bought it from a xs member back in the day that tried to volt mod it and failed and killed the card. I bought that card for $40 and soldered it for 4+ hours and now it works Its ugly looking as I was just getting into soldering.. -now I have a weller ws51
1.55v lol it wasnt the best overclocker ram was at 1.21 I think I dont really remember. Clocks are 840 core, 2200 Shader, 950 mem. I think these are right, but this is just from memoery so dont shoot me if that shader is really far off. But I think the rest are close
Paired with a 24" flat screen monitor
Still waiting on a lot parts, most should get here tomorrow, damn weekends and no shipping lol
I know this a crude worklog, I just thought I would throw it up here and see what happened.
I am going to cut and sleeve all the fans together, I have filters for all intake fans 6 total.
Basically will update tomorrow with whats going on, If you would like any more pictures please ask, these are crude at best, I shot them quick and I don't think the auto focus was on for half of them
I have a gigantic mess, thats what happens with my projects when I get into a hurry and have a dedicated table.
See big, mess with crappy picture
The front
Side
rad1
rad2
rad3
rad4
rad5
mess
tap set - handy for used radiators I tapped all the used ones to 6-32. kept thermochill that way it was with #6 sheet screws
some yate loons
motherboard in progress
otherside of case
pump mount 1 brilliant I tell you
pump mount 2 -yes ingenious I know
both pumps in perspective
Heres the pump that I killed
Another case view
My handy fill valves as no reservoirs will be used in this build
12 feet of pretty tygon r-3400 tubing for my two loops
