I have an old socket A system that I just swapped the motherboards on. I just did an XP Repair install so it would boot on the new chipset. Everything is working fine except for the ATI Drivers. If I install them and reboot, the computer will usually crash within 5 minutes. If I uninstall the drivers, the computer will run with no problem at all, the display is just very choppy.
It is an
Athlon XP 1700
Soyo SY-K7ADA V1.0 mobo
512MB PC3200 DDR
x800 Pro AGP unlocked to 16 pipes
Windows XP Home
In the past I have used this video card with this same mobo without any problems at all, so I know it is not a compatibility issue.
