That particular fet is the one that tends to burns only because half of the wattage the GPU chip eats flows through it.
You were not supposed to see this.
Sorry for your loass manufacturers should stop using cheap ty components that burn up this bad. I've never had a VC die on me in this way. Probably because I hear even one story of something like this I know there will be more - many more, just like it. So I opt for something different.
"Prowler"
X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
Cooling:
6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
Modded X570 Aorus UEFIs
I am sorry for your losses.
It must be a fault on maybe just a few 8800gt because it looks like the same chip. Did you manage to RMA it btw?
