Results 1 to 18 of 18
Thread: Need some help
    Jan 2007
    Need some help
    Hi guys
    Im going to paris to see family and lucky for me theres one Store i found that sells good WC parts this is what im getting.
    Swiftech Apogee GTX
    Pompe Swiftech MCP355 + XSPC Laing Acrylic Reservoir
    Im on a budget now heres where I need help what rad should I get between these two this setup is only to cool one cpu.
    Black Ice GTS Lite 240 or XSPC RS240 Black ?
    What tube size 10-13mm or 13-19mm?
    Life's Replay
    Mar 2008
    Switzerland | Zürich
    10-13 is 5/8" ID tubing, 13-19 is 1/2" ID tubing.
    The XSPC RS240 is said to be quite good with low CFM fans at least, what kind of fans are you planning to run?
    Self-proclaimed and convincing.
    Intel i5 760 | Prolimatech Genesis CPU Cooler | EVGA GTX 480 | Arctic Cooling Accelero Extreme Plus II GPU Cooler | Corsair Vengeance 4 x 4GB DDR3-1600 | Crucial C300 64GB SSD | 5 TB+ of storage | Corsair Obsidian 550d | Corsair HX850
    13" Macbook Pro
    Nikon D90 | Nikon 55-200mm f/4-5.6 VR | Nikon 35mm f/1.8G | Sigma 17-70mm f/2.8-4.5 Macro HSM | Nikon SB-900 | Braun 5000
    Twitter | Life's Replay
    Aug 2002
    .CA
    My opinion would be to grab the XSPC RS240 and some 13mm (1/2" for our American friends) tubing. See if the store has the new Swiftech GTZ. While the GTX would work just fine the new mounting system of the GTZ really makes it shine.
    You can check out Martin's review of the RS240 on his website. It should help you to pick out some fans. http://www.martinsliquidlab.com/XSPC...or-Review.html
    [edit] Damn and I thought I typed fast O_o[/edit]
    If my answers frighten you, stop asking such scary questions...
    • Hush V2
    • Intel i7 4770K - XSPC Raystorm - Gigabyte G1.Sniper Z87 - Crucial Ballistix DDR3-1866 - 9-9-9-24
    • Zoltac Geforce GTX 780Ti - EK-FC780GTX Ti
    • SanDisk Ultra 480GB SSD - WD Black 1TB 64MB Cache
    • Custom Water Cooled Fractal Designs Define R4 - Antec HCP-1000 Platinum
    • EK Coolstream XTC 280 - Cougar CF-V14HB Vortex HDB - XSPC EX240 - Scythe GT AP-15
    • Dazmode Storm DDC 3.25 - AquaComputer Aqualis DDC 150 Reservoir
    Life's Replay
    Mar 2008
    I'd get the smaller tubing, there is no performance hit using the smaller one and it looks a lot sleeker, plus it's easier to handle in my opinion.
    13" Macbook Pro
    Jan 2007
    Thanks for your help guys I have 4 80cfm fans but I can lower the cfm.And yes the store has the Swiftechs GTZ and D-Tek Fuzion V2 for 10 euros more which is better?and also for the 13mm tubing I wont need new barbs for the cpu block or Pompe Swiftech MCP355 + XSPC Laing Acrylic Reservoir correct?
    Xtreme Mentor
    Oct 2007
    USA
    You'll need 120mm fans for the rad unless you build a shroud. 80 mm wouldn't cover the rad surface enough, you'd lose a lot of rad performance.
    All stock for now, no need for more, but it's gonna be soon methinks.
    Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
    SLI GTX470 EVGA
    EK HF nickle blue top CPU block (free from Eddie)
    Koolance 470 waterblocks
    One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
    Banchetto Tech Station
    120 GB SSD, and a few other drives.
    1000W UltraX3 PSU, 900 watt (1500VA UPS
    23.999" Acer GD235hz and 24" Acer H243H
    Life's Replay
    Mar 2008
    Quote Originally Posted by malik22 View Post
    I would invest a few euros in some proper barbs/compression fittings, it's worth the investment and guarantees a fit.
    I have the pump and it was a really tight fit with 10 mm tubing, not sure how it's with 13 mm.
    About the fans, get some 120 mm fans if you can, otherwise there is no point in spending more money on a better block, your temps will still be mediocre at best.
    13" Macbook Pro
    Jan 2007
    They are 120mm I wrote they have 80cfm inCore why the barbs that come with the GTZ block arent good?
    and also have you guys heard of magicool rads are those any good?
    Aug 2007
    Brasilia - DF - Brazil
    What is the store you getting parts?
    I'll be in Paris in 4 weeks, maybe I'll order something too.
    My Lian Li G70
    Asus P6X58D-E * i7-930 * Saphire 7970 * 6GB Corsair XMS3 1600 C7 * Crucial M4 256GB SSD * Lian Li G70W Powdercoated
    Watercooled by single loop Coolgate Quad 120 + Swiftech MCR220 with San Aces H1011 * EK Supreme HF * Koolance VID-AR797 * EK Asus X58 full set * DDC 3.25 with EK Dual Top/Res
    Jan 2007
    Quote Originally Posted by leo_bsb View Post
    Im not ordering im going to the store heres the address
    156 Rue de Chareton 75012 Paris
    the name is Opium-PC
    Jan 2007
    Quote Originally Posted by mcoffey View Post
    Opium PC...dude...you sure you're not walking into some Hash den Is the US, we got one called Crack House Computers and you don't want to be going there for no PC parts
    andyc
    if i was in Amsterdam i wouldnt be suprised
    Jan 2007
    I have one last question I called them up and they also have this pump in stock Laing DDC-1T+ 3.2 is it much better then the swiftech MCP355 or ist not really needed for what im doing?And also do the GTZ D-Tek block come with the right barbs for 10 13mm tubing?
    Jul 2008
    Lost
    DDC 3.2 is the same thing as the MCP355. If I'm doing my conversion right, 13mm == 1/2in, in which case, yes, the GTZ comes with 1/2" barbs.
    Edit: See my follow up post. I missed the 10 on the front there and thought you meant 13mm tubes.
    Curiosity was framed, Ignorance killed the cat.
    Jan 2007
    And how about the D-tek what barbs does it come with and will 1/2 fit with the 10 13mm tube im gonna get or do I have to get 19mm?
    Jul 2008
    Lost
    If 10mm is the ID of the tubing, then I believe that's ~3/8" which is still fine on the GTZ (it comes with both 1/2" and 3/8" barbs), but I don't know about the D-Tek. I know when it's ordered from performance pc you can specify if you want a 1/2" barb or a 3/8" barb, but not sure what it comes with stock.
    Edit: I see on Petras it lists 1/2" barbs, so unless you have 1/2" ID tube (13mm ID) you'll need to get some replacement barbs.
    Jan 2007
    Thanks again im all set now I have been reading around and heard people suggesting the Ek supreme should I look into this or just get the D-tek or gtz that will depend which of those two is in stock.
    Banned
    Feb 2008
    Slappyville - North Bay,CA
    GTZ & VeeTec V2 is less restrictive than the EK
  18. #18
    Life's Replay
    Mar 2008
    You're right, my bad.
    I wouldn't bother with the EK supreme, the Laing DDC-1T / Swiftech 355 should be fine with the Fuzion and GTZ.
    13" Macbook Pro
