I need to get some quick disconnects for a radbox build. I've narrowed it down to 2 models from Colder as potentially being the best and least flow restrictive. Which one is a better choice do you think?
1. HFC12
Main Components: Polypropylene
Coupling Size: 3/8"
Pressure: Vacuum to 60 psi, 4.2 bar
Temperature: 32° to 160°F /0° to 71°C
Materials: Polypropylene
Thumb latch: Polypropylene
Valve spring: 316 stainless steel
Panel mount gasket: EPDM
External springs: 316 stainless steel
O-rings: EPDM
Color: Light gray with charcoal gray latch
Tubing Range: 3/8" to 3/4"
2. NS6
Main Components: Glass-filled polypropylene
Coupling Size: 3/8"
Pressure: Vacuum to 120 psi, 8.3 bar
Materials:Glass-filled, polypropylene
Thumb latch: Glass-filled, polypropylene
Valve spring:(wetted) : 316 stainless steel
Panel Mount Gasket: EPDM, FKM
O-rings: EPDM or FKM
Hastelloy C External spring: 316 Stainless Steel
Soft touch overmold: TPV (thermoplastic vulcanizate)
Color: Gray with dark gray overmold standard (gray with red or blue overmold available)
Lubricants: Krytox PFPE (inert)
Spillage: ~0.03 cc/disconnect @ 0psi, ~0.30 cc/disconnect @ 120psi
Tubing Range: 3/8" and 1/2" (9.5mm to 12.7mm)
Does "glass filled" matter at all?
Does barb size matter when the couplings are the same size diameter?
Is Cv an accurate measurement with our lower flow rates?
Are 2 of these too much restriction for 1 loop!
