+ Reply to Thread
Results 1 to 5 of 5
Thread: Is the 2500+ Barton right for me?
    Oct 2002
    0
    Well I haven't read up on any computers since I got my system setup almost a year ago and I need a little help here.
    Here is my current setup:
    AMD 1600+
    Abit KD7-E
    Radeon 9700 Pro
    Turtle Beach Santa Cruz
    512 MB Corsair XMS 3200 C2
    TTGI-420SS Power Supply
    Seagate Cuda IV 40GB
    It's cooled by a Maze 3, Maxi-Jet MP 900, Heatercore, and 2 120mm 85 CFM fans.
    I plan on only replacing the 1600 with the Barton 2500, are there any foreseeable problems I could get from switching to the Barton? Thanks
    EDIT: Also, I'm planning on putting the 1600+ in my pops computer, if I were to get the retail Barton, would the heatsink fit the 1600+ and a ECS K7S5A?
    Xtreme Addict Perc's Avatar
    Apr 2003
    USA Tampa FLA
    0
    im not to sure about your mb? if anything you may want to get your self a nforce2 mb like the abit nf7-s series. other than that your hardware looks good to go....
    perc,
    Nov 2002
    Los Altos, CA / Las Vegas, NV
    0
    The 2500+ retail heatsink is a copper core model, so it should work fine with the 1600+. Definitely so if you are going to run at stock speed anyway.
    I don't have any experience with the KD7, but you will probably have to update BIOS to get Barton compatability if you aren't using a BIOS version that supports one already.
    Mar 2003
    New York State
    0
    You might just need to update the bios. You should be fine after that.
    Oct 2002
    0
    Alrighty, I'm putting the order in right now.
+ Reply to Thread
