2x Asus P8Z68-V PRO Bios 0501
i7 2600K @ 4.6GHz 1.325v / i5 2500K @ 4.4GHz 1.300v
2x G.SKILL Ripjaws X Series 8GB DDR3 1600
Plextor M5P 256GB SSD / Samsung 840 Pro 256GB SSD
Seasonic X-1050 PSU / SeaSonic X Series X650 Gold PSU
EVGA GTX 690 (+135%/+100MHz/+200MHz/75%) / EVGA GTX 680 SC Signature+ (+130%/+80MHz/+200MHz/70%)
I have updates guys. I turned off the PhysX from the drivers. The greatest news is that it is all about the shaders on this card. I had my shaders at 1516 and I thought it was stable but my GPU would not overclock past 700 with those shaders and it would not even pass 1 run of 3D mark - greatly unstable to overclock past 650mhz on the core with shaders > 1500. Than I lowered them to 1458 and that gave me headroom to push the GPU to 730mhz. I have ran 3D mark Vantage a few times with absolutely no artifacts or hiccups. This is not the maximum overclock of the card. I have yet to see where is the limit of the memory and the GPU with those new shaders speed. So given those discoveries i have ran vantage a few times at 730/2430 with PhysX disabled(many ATI people don't like the results with PhysX so I had to disable it):
ps: I have very important update. There is some really weird stuff going on with the shaders. Before i was trying to do vantage on 700 core and shaders of 1512 but i had absolutely no chance in completing even 1 run, the whole thing was going black screen 2 minutes in the run. After I saw Dejan's post about the shaders and the core clocks I decided to skip the range between 700 and 730 with 1512 shaders and jump directly to 756 mhz. Surprisingly it passed vantage with absolutely no problems or artifacts. So the moral of the story is to NOT set up high shader values and than force core clock of anything less than 730... Here are the new scores:
ps2: Ok guys i played around and the final values are 756 core/1512 shader/1224 memory. For core speed higher than 756 i need higher shade speed than 1512 - EVGA precision does not let me set a higher value than 756 with 1512 shaders, so i try to turn up the shaders but the next option is 1566 which is not stable. The maximum is somewhere between 1512 and 1566 and for that i would need RIVA TUNER but don't want to install it now... Nonetheless, that would give me like 10-20 mhz max which is not significant since the memory is maxed at 1224. here are the final results:
i9 9900K/1080 Ti
Hey largon why don't you post up links to these G92 cards that leave the 260GTX in their wake. I have not seen them.
1262. 3Dmark 2005 - 20281 marks - largon (Team Finland) - (GeForce 8800 GTS 32... @ 756/1107mhz on h2o)
1669. 3Dmark 2006 - 13632 marks - largon (Team Finland) - (GeForce 8800 GTS 32... @ 729/1152mhz on h2o)
I can't find where you even own one.
So keep on trolling.
WZ
PS. my scores with a Stock cooled 8800GTS 320 absolutley crush your H2O cooled one. Perhaps you better just concentrate on your equipment.
WeldZilla,
Firstly, for your information, those are not G92s, they're age-old G80s. 320MB RAM hello?
And secondly, I'm not interested in 3DMark. It's a CPU benchmark.
Third, I haven't updated my HWBot in, what, a year now?
Fourth point, read my post. Here, let me quote myself:
My current G92-400 (GTS) with benchable shader core @ 2.43GHz (= 622GFLOPS) beats a stock G200-100 (= 497GFLOPS, ~600GFLOPS if MUL works about 40% of time) by 25%.
^ my 1st claim -> □
Once you watercool/vmod (of which latter doesn't gain anything) & OC a G200-100 to maximum you might reach some 1.574GHz shader core (604GFLOPS, ~725GFLOPS if MUL works... 40%).
^ my 2nd claim -> □
And those are just my results. I'm sure there are better ones out there.
Was there something else?
PS.
And, as an interesting detail, none of the G200s in this thread can match in texture fillrate against a G92...
You were not supposed to see this.
OK now post a benchmark as opposed to a stress test..
you know 3D03, 3D01SE, 3D05, Aqmk3, 3D06, hey even the Devil May Cry bench we have seen of late.
I will say that is a great furmark score. Nice temps too.
WZ
FINLAND pwn everythng! gtx260 is coming..
Corsair Obsidian 650D - EVGA P67 FTW - Samsung F3 1Tb - 8Gb A-Data cheapest crap DDR3 - Intel Core i5 2500K w/ Corsair H50 - EVGA GTX 295 co-op - Corsair AX650
I look forward to seeing you post up some results pcaddict!! sooooooon
WZ
Yesterday i recieved my two evga 280GTX cards , and the install them in SLI
the performance is very impress , i can play crysis and crysis warhead with ultra high setting and 16AF - 16AA very smooth without any lag
Gaming rig;
ASUS RAMPAGE IV BLACK EDITION
I7-4390K
G.SKILL Trident X 16GB 2400
Intel 530 240GB
2x Asus GTX780
Corsair AX1200
HP ZR30w 30
Win 8.1 pro
Sound rig;
Auzen X-Fi H.T. HD --> Yulong D100 MKII --> D-7100
Final clocks...
ASUS P6T Deluxe V2
INTEL74 CORE I7 920 D0 (3924A346) 20*180MHz ~ 1.176V @ SCYTHE MUGEN2
3*1GB MUSHKIN XP3 @ 1440MHz CL7-7-7-21 ~ 1.60V
ZOTAC GeForce GTX260 @ 650/1300/2400MHz ~ ARCTIC COOLING ACCELERO GTX280
CORSAIR VX-550W
>>Micron D9 based RAMs and Electromigration<<
HUNGARY
Done some furher testing, then again, Furmark stable.
ASUS P6T Deluxe V2
CORSAIR VX-550W
HUNGARY
MAIN: 4770K 4.6 | Max VI Hero | 16GB 2400/C10 | H110 | 2 GTX670 FTW SLi | 2 840 Pro 256 R0 | SB Z | 750D | AX1200 | 305T | 8.1x64
HTPC: 4670K 4.4 | Max VI Gene | 8GB 2133/C9 | NH-L9I | HD6450 | 840 Pro 128 | 2TB Red | GD05 | SSR-550RM | 70" | 8.1x64
MEDIA: 4670K 4.4 | Gryphon | 8GB 1866/C9 | VX Black | HD4600 | 840 Pro 128 | 4 F4 HD204UI R5 | 550D | SSR-550RM | 245BW | 8.1x64
Hey guys, been working on my new build for some time and have got some results now. My GPU loop is pretty sick and consists of EK GTX280 FC with the LC ram back, DDC-2 w/Petra top, Feser Xchanger 120.3, 3x Sanyo Denki 120x38mm San Aces'.
I have an XFX GTX 280 Vanilla but am getting pretty impressive clocks out of it. Top so far is 792/1620/2664 Vantage stable.
Here is my Vantage result, but has PhysX driver enabled...
http://service.futuremark.com/compare?3dmv=413340
Will have more validation shortly, but seems pretty solid and I think I have more in the memoryclock department.
Q6600 3.6Ghz @ 1.276v | DFI LP LT P35 | Ballistix Tracer PC2-8500 600Mhz @ 2.074v | GeForce 260 GTX | Auzen X-Fi Prelude | PCP&C 750 | Arch Linux ~ WinXP
AMD Athlon 64 X2 3800 | DFI LANParty NF4 SLI-DR | 2x512MB G.SKILL PC3200 BH-5 | OCZ PowerStream 520W | Palit GeForce 9600 GT | Gentoo
Long Live DFI.
I was thinking of Vmodding the card, but read that it has minimal gains and cooling is more of an issue. I think I have that covered
Also dont want to fry the card and have no warranty, I am eyeballing a QX9650 LOL, need to save my cash for that
Also want some Murdermod parts for my TJ-07
Thanks for the kind word nfm
I just RMA'd my dead GTX 280 ( the good one doing 771/1566/2808 on stock cooling & stock volts )
Coding 24/7... Limited forums/PMs time.
-Justice isn't blind, Justice is ashamed.
Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Crystal Chen, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Dan Snyder, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Mike Clements, Alex Ruedinger, Oliver Baltuch, Korinna Dieck, Steffen Eisentein, Francois Piednoel, Tanja Markovic, Cyril Pelupessy (R.I.P. ), Juan J. Guerrero
Thanks, its all me
I am really glad I got a good GPU. I spent a fortune on cooling for it, so I am happy it was worth it
And sorry to hear of your dead card BenchZowner. Seems luck has not been on your side lately. I just wanted to say I really enjoy your hard work and hope your luck improves.
Edit: a few pics
my card suck when it come to shader overclocking, stuck at 1402
At 1458 , ATItool artifacts right away, any ideas ??
fan @ 70 %
EDIT : Riva Tuner does not let me set any thing between 1402 and 1458
Water cooled - running like this since I got it about 2 months now. Game stable, furmark, vantage, etc.
Don't hate
i7-2600k @ 4.8Ghz 1.38v L044A892
ASUS P8P67 LGA
16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
Cooler Master UCP 1100 Watt PSU
GTX 680 1300/7000
Lian Li PC V-2000
largon.....have a look here at the texture fillrate............granted your G92 is excellent also.
http://www.xtremesystems.org/forums/...2&postcount=47
This is ridiculous. How come my GTX 260 is only stable up to 685 while everyone else is getting well into the 700s?
Are you guys running your cards with a BIOS volt mod?
Intel Core i7 6900K
Noctua NH-D15
Asus X99A II
32 GB G.Skill TridentZ @ 3400 CL15 CR1
NVidia Titan Xp
Creative Sound BlasterX AE-5
Sennheiser HD-598
Samsung 960 Pro 1TB
Western Digital Raptor 600GB
Asus 12x Blu-Ray Burner
Sony Optiarc 24x DVD Burner with NEC chipset
Antec HCP-1200w Power Supply
Viewsonic XG2703-GS
Thermaltake Level 10 GT Snow Edition
Logitech G502 gaming mouse w/Razer Exact Mat
Logitech G910 mechanical gaming keyboard
Windows 8 x64 Pro
There's no BIOS volt mod for the GTX 260 & GTX 280 cards Carfax.
Why do you think my card is such a ty overclocker then? Is it just born that way?
I checked my voltage using Nibitor and it's at 1.12v for extra.
I might take off the heatsink today and see if it has any thermal paste on it.
C'mon guys, I need some help.. What do you think I should do? My temps hits 60c at 700mhz on 100% fan speed, so it's not like it's getting that hot.
Intel Core i7 6900K
Noctua NH-D15
Asus X99A II
NVidia Titan Xp
Sennheiser HD-598
Samsung 960 Pro 1TB
Viewsonic XG2703-GS
Windows 8 x64 Pro
There are good cards and bad cards. Overclocking-wise.
You might be lucky and pick a 730+ MHz GPU GTX 280 or a 680-690MHz max GPU.
So far I had 4 GTX 280s, one of them was benchable at GPU:771MHz/SPs:1566MHz... my second best now is a 753MHz/1512 card.
There's also another factor, stability.
Some believe that 1 hour of gaming is fully stable, others don't.
And of course...there's also the "lie" case.
Beneficial or not, some people tend to lie on such stuff for no apparent reason.
