This my POV 260 GTX on stock cooling..
This is interesting. It appears that 1512 stable on the shaders is the limiting factor of these cards. It also appears that cooling the chip further doesn't allow you to run the shaders faster.
So unless someone has a really exceptional chip it appears likely that the limits to this card is 756/1512 stable. I'm sure the core could go faster but is limited by the shaders.
EVGA X58 Classified-Win 7 RC 64
Corsair HX1000
Mushkin Redline 6-7-6-18
EVGA 295x2 Aqua blocks
Coolermaster ATCS 840
i7 920 D0 - HK V3
Thermochill 2x120
XSPC RX 360
Vertex 120, Velociraptor 300
Q6600 3.6Ghz @ 1.276v | DFI LP LT P35 | Ballistix Tracer PC2-8500 600Mhz @ 2.074v | GeForce 260 GTX | Auzen X-Fi Prelude | PCP&C 750 | Arch Linux ~ WinXP
AMD Athlon 64 X2 3800 | DFI LANParty NF4 SLI-DR | 2x512MB G.SKILL PC3200 BH-5 | OCZ PowerStream 520W | Palit GeForce 9600 GT | Gentoo
Long Live DFI.
Here is my max linked core / shader clocks one notch higher on the core and instant artifacts - still playing with memory.
i7-2600k @ 4.8Ghz 1.38v L044A892
ASUS P8P67 LGA
16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
Cooler Master UCP 1100 Watt PSU
GTX 680 1300/7000
Lian Li PC V-2000
, 1566Mhz is nothing to sneeze at . Were you able to do the same shader with stock cooler before or you did not try?
Long Live DFI.
As far as I know you cannot change the core/shaders ratio, sorry guys.
I've just modded my best GTX 280 and I'm preparing the other components for a LN2 session this Wednesday.
Coding 24/7... Limited forums/PMs time.
-Justice isn't blind, Justice is ashamed.
Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Crystal Chen, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Dan Snyder, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Mike Clements, Alex Ruedinger, Oliver Baltuch, Korinna Dieck, Steffen Eisentein, Francois Piednoel, Tanja Markovic, Cyril Pelupessy (R.I.P. ), Juan J. Guerrero
ASUS P8P67 LGA
GTX 680 1300/7000
Lian Li PC V-2000
I can run at 1566 but it is not totally stable. I did finish a 3D06 at 1566 but my 1512 shader did better because when I ran 3D06 at 1566 I saw artifacts a couple of times during the test. If you ever see artifacts while running a test it will kill the results.
I have the stock cooler but I have used AS5 on the spreader. Once you get to 1566 on the shader, if you want to increase the core past 756, you have to jump to something around 780. With my cooling I am not stable at all at that speed, so the best I could do was 756/1566, but not stable.
Corsair HX1000
i7 920 D0 - HK V3
Thermochill 2x120
XSPC RX 360
ASUS P8P67 LGA
GTX 680 1300/7000
Lian Li PC V-2000
I think you are right about that. On the other had I just got a 280SC and I think it may run clock a little faster than my 260. The trouble is that it overheats too quickly and I don't have water. I'm going to order an aftermarket cooler as soon as they start selling them(thermaright). The memory on the 280 will run at 1400 until it gets up to the mid 70s temp and then starts artifacting. Also the shaders will run at 1566 until the heat gets higher. Not sure about the core yet as it seems to max out in the 730s but here again I hope some cooler temps will help this also.
Corsair HX1000
i7 920 D0 - HK V3
Thermochill 2x120
XSPC RX 360
Since ATI cards have so many issues i decided to go with Nvidia, again. The cheapest GTX 260 is EVGA GEFORCE GTX260 for 244 euro and the chaepest GTX 280 is GAINWARD 9351 GTX280 1GB or XFX GEFORCE GTX280 1GB GX-280N-ZDF for 390 euro. Do u think the extra 150 euro worth it, either they both run overclocked or not.
I can also get XFX GEFORCE GTX260 896MB XXX for 295 euro. Count this option in too.
Intel i7 3770K (4.8Ghz@1.36v) ~ Asus Maximus V Gene ~ 8Gb G.Skill Ripjaws X 2133 C9 (@2400 C10) ~ Asus GTX 670 DCUII (1230/7000) ~ Samsung 840 Pro 128Gb ~ WD Black 1Tb ~ Corsair AX 850W ~ X-Fi Titanium Fatal1ty ~ Epoz Aktimate Mini ~ Ducky Shine Blue Led /w MX Red ~ Logitech G700 ~ Samsung S27A850D 27" (2440x1600) ~ SilverStone TJ07B-W
WaterCooled by XSPC Raystorm ~ TC PA 120.3 + 3xAP 15 ~ MCP655 with EK-D5 X-Top Rev.2 ~ EK Multi 250
Powered by APC Smart-UPS SC 1500 ~ MGE ellipse premium 500
Take one very eager 260GTX and strap one crazy E8400 Rocket to it's ass and let them go.
you won't be disappointed!!!
This combination just keeps getting faster and faster!!
It's very hot here now but winter is coming!!!
My Card is the MSI although I believe them all to be quite great.
WZ
hmm my 280 with ref cooler and modified memory timings in bios.
http://www.techpowerup.com/gpuz/nhu6u/
735 core, 1512 shader, 2700 memory.
no matter how much more i loosen timings wont go next step up on memory, needs more voltage. it's stable for gaming all day long and benchmark thrashing at those clocks.
DFI LT-X48-T2R UT CDC24 Bios | Q9550 E0 | G.Skill DDR2-1066 PK 2x2GB |
Geforce GTX 280 729/1566/2698 | Corsair HX1000 | Stacker 832 | Dell 3008WFP
just ordered two EVGA 280GTX from newegg
i intend to kill my games with SLI setup
Gaming rig;
ASUS RAMPAGE IV BLACK EDITION
I7-4390K
G.SKILL Trident X 16GB 2400
Intel 530 240GB
2x Asus GTX780
Corsair AX1200
HP ZR30w 30
Win 8.1 pro
Sound rig;
Auzen X-Fi H.T. HD --> Yulong D100 MKII --> D-7100
little bit offtopic,but should I upgrade my 7950gx2 to gtx 260? cuz I need new graphics card and gtx 260 looks nice..
Could gtx260 handle SkethUp, photoshop and other stuff like that smoothly? (and of course some games like crysis, bf2142)
Corsair Obsidian 650D - EVGA P67 FTW - Samsung F3 1Tb - 8Gb A-Data cheapest crap DDR3 - Intel Core i5 2500K w/ Corsair H50 - EVGA GTX 295 co-op - Corsair AX650
Photoshop is CPU and Memory based
And for gaming of course It will handle them.
Sony PS3 | Nintendo Wii + Nintendo Wii Fit
By Mercedes - Adventure Trips around Middle Europe in a Youngtimer | https://www.facebook.com/S.Mercedesem - Like Us, if you Like us that is
okay, Bfg gtx260 is coming in few days
I'm ready
oh sweet. Loving the thermalright on the shader chip!
Silverstone Temjin TJ-09BW w/ Silverstone DA750
Asus P8P67
2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
8GB G.Skill DDR-1600 7-8-7-24
Gigabyte GTX 460 1G
Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
1 X 120GB OCZ Vertex
1 X 300GB WD Velociraptor HLFS
1 X Hitachi 7K1000 1TB
Pioneer DVR-216L DVD-RW
Windows 7 Ultimate 64
that looks cool
Finally... after a 2 month odyssey the RMA 280 arrived. And it clocks excellent - happy camper over here
I hate you for those clocks , I really do !
GPU-Z Temps please ?
Very nice clocks Mango. Temps look to be 50 degrees to me. Has to be watercooled. I would like to see a 3DM06 score just for comparison. And what happens when you clock your core to 783?
Corsair HX1000
i7 920 D0 - HK V3
Thermochill 2x120
XSPC RX 360
Long Live DFI.
