alright..im just curious to see what you would think of these fans.
http://www.newegg.com/Product/Produc...82E16835103052
they are CM 120mm 44cfm ~20db sleeve bearing
pros cons?
3 out of the 4 will be on a MCR320 rad
1 will be a case fan
they are cheap so im sure they wont last as long as the better fans that are $20 each but..what im sort of wondering is..are the stats on the fan published by CM correct? also will the sleeve bearing fan last when its positioned Horizontally**edit __ instead of |
thanks for any replies..im almost done ordering my new WC setup just have fans left to choose..
