try using this Magicool cpu waterblock it should be much bigger than 50mm
and its only 33 bucks
http://www.hardwarecanucks.com/forum...pogee-gtx.html
hmm im thinking belt sander? Lawl anybody know if this world work?>
also the bottom of the peltier is still 62mmx62mm and the cpu is 50mmx2 lol so yuh still a problem
That magicool block is still about 50mm and the temps are poor. I'd not recommend that. Unless you're saying to sand down the block and then lap the surface... That would be interesting. =)
Shifteh: Not a good idea to use belt sander because it will produce a very rough surface (unless your talking about that magic block). Since you have a 60mm TEC you need a hot and cold plate. Then you should fasten both together, so the order from top to bottom:
Block
TIM
copper hotplate
TIM
TEC
TIM
copper coldplate
TIM
CPU
I believe there are some good guides on how to lap the surfaces of the plates. Remember these should be very flat/perfect surfaces... Also pressure between the cold/hot plates should be 150psi for best results. Just using the block and MB will get you about 40psi without a backplate and 75psi with. Over tightening the block will make your MB stress and not boot (most of the time you can just loosen the block and it will boot again). Uncle Jimbo is a resident expert on mounting pressure.
Current: AMD Threadripper 1950X @ 4.2GHz / EK Supremacy/ 360 EK Rad, EK-DBAY D5 PWM, 32GB G.Skill 3000MHz DDR4, AMD Vega 64 Wave, Samsung nVME SSDs
Prior Build: Core i7 7700K @ 4.9GHz / Apogee XT/120.2 Magicool rad, 16GB G.Skill 3000MHz DDR4, AMD Saphire rx580 8GB, Samsung 850 Pro SSD
Intel 4.5GHz LinX Stable Club
Cool,
Questions
#1 how do i test for pressure i dont have a torque wrench or anything i could just have the plates bolted together,
#2 is TIM thermal compound and which one would you recommend i was thinking arctic silver 5 or whatever its called
Im going to sims metals out derwent park or some ware and ill try and acquire the copper, then ill see if i can get purden engineering to mill the bottom of the coldplate to have a piece that fits on the cpu
dang this uncle jimbo seems to be an expert in everything!!
can you show us some pics on how to torque theplates?
http://www.xtremesystems.org/forums/...09#post3234509
go to page 3 post #73 by Uncle Jimbo
Thanks zipdogso cheers
ill use ceramique on the pelt then and AS5 on the cpu to block and block to watercoolingblock
thanmks unclejimbo for the torque post i think ill try and find a torque screwdriver that might be easier
mk ceramiqe it is then
AR5 or ceramiqe on the hot plates to waterblock?>
the tec should be here anyday , coming from shanghi
Woot the TEC's arrived it has small chips on 2 corners , will this be a problem? approx 2mm chipped off silicone still holding chips in place
:P its huge like double the size of a normal one :P im going to find a heatsink and run some tests :P
is it still sealed?
i pulled a chip off and i can see metal about a 1mm worth of leak and anouther with about 1mm again???
there both on one side
is it sealed so the cold side does not create condensation and damadge parts???
i sucked on one leak and air comes from the other little leak so yuh lol theres a leak
there only tiny leaks btw
and like there corner chips not in the middle or anything
oh and btw the chips are ceramic chips not the elements Lawl
*updated*
Aww come on peoplez peeze anser i want to power it up , just want to know if it will up
i was thinking id make a minute amount of epoxy and dab it on the hole's and it would seal it but should check with u guys if this would work? its like somebodies knocked the spikey ceramic corner and its like snapped only a little
Just hook a remote switch (button) and turn that thing on if it blows....uh.....RMA it or ask for your money back, since it came like that...
Intel Core 2 Q9450 @ 3.9Ghz @ 1.4v
Asus P5E3 Premium Wi-Fi
2x1GB OCZ Platinum Edition DDR3 1520 Mhz, 7-7-7-20
ATI Sapphire Radeon HD4870 @ 790/1100
LC Power Arkangel 850W 4-Rail PCIe 2.2
Zalman CNPS9700 Green Led
4xScythe Slip Stream 1900RPM
Coolermaster Stacker 832
2x Western Digital Caviar 500GB Raid0 (1TB) SATAII
well i have seen unsealed units so meh ill go and get some epoxy and fix it
*prays to satan*
*Also asks for bag of unlimited ch33ze and chicken burgers that are not addictive or have devil like tricks that will me over
oh well ive put epoxy in the holes so yuh lol ave to waits
Well it seems everyone is out for the moment!! Since I am no tec pro, I am unsure if the epoxy would work. The only thing I can foresee is too make sure that the epoxy is capable of handling the temperatures (extreme cold/hot). If so, then I don't see why it couldn't work!! Good luck.
my guess is chip will be dead.
sorry I will not be replying much. you can see why here
can U post a pic of the broken parts of the tec?
thanks repsol
