Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: Dual CPU mobo for nehalem from foxconn?
    Wuf
    Jul 2007
    Finland/Tampere
    Could u guys make an DP mobo for DP xeon nehalems if those cpus have OC capabilities for us dual socket fans in xs and other cpu bite crunching maniacs ?
    I'm certainly gonna get set of 2 nehalem xeons, mobo for them and couple gigs of ddr3 pretty soon after their release...
    You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
    [22:53:09] [@Jaco-XS] i'm gonna overclock this damn box!
    Ze gear:
    Main rig: W3520 + 12GB ddr3 + Gigabyte X58A-UD3R rev2.0! + HD7970 + HD6350 DMS59 + HX520 + 2x X25-E 32gig R0 + Bunch of HDDs.
    ESXI: Dell C6100 XS23-TY3 Node - 1x L5630 + 24GB ECC REG + Brocade 1020 10GbE
    ZFS Server: Supermicro 826E1 + Supermicro X8DAH+-F + 1x L5630 + 24GB ECC REG + 10x 3TB HDDs + Brocade 1020 10GbE
    Lappy!: Lenovo Thinkpad W500: T9600 + 8GB + FireGL v5700 + 128GB Samsung 830 + 320GB 2.5" in ze dvd slot + 1920x1200 @ 15.4"
    Xtreme X.I.P.
    Nov 2002
    Shipai
    mhhhh dual socket ocing is quite tricky... let me check into that with our engineers ok?
    Wuf
    Jul 2007
    Finland/Tampere
    Quote Originally Posted by saaya View Post
    Ok thx.
    Far as i know the upcoming X58 chipset supports Dual prosessor option.
    After the skulltrail publishemt Dual cpu comps won't be that rare as they used to be in normal desktop use... Just good OCing mobo needed
    Hopefully this generation of DP xeons uses regular DDR3 and not DDR3 ECC or DDR3 FB-DIMM, would be much cheaper and they won't limit fsb like DDR2 FB-DIMM did.
    E: After little wikipedia reading i found this out :P
    Gainestown is the codename for DP nehalem Xeons, they are Quads with HT (4 physical cores, 8threads at same time), they use LGA1366 socket, supports DDR3 in triplechannel, TPD is 130W/chip and their relase is at Q3 2008.
    http://en.wikipedia.org/wiki/Nehalem_(microarchitecture)
    Ze gear:
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    Dual socket? I smelled this thread a mile away..
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
    Wuf
    Jul 2007
    Finland/Tampere
    Quote Originally Posted by Movieman View Post
    Sure u did :p
    Ze gear:
    Xtreme X.I.P.
    Nov 2002
    Shipai
    i was surprised you didnt start a thread about this yourself about 2 motnhs ago or so
    solid, the xeons will use ddr3 ecc, but no more fbdimm, at least as far as i know.
    and x58 is essentially a server chipset, so yeah, its built for multi cpu configs.
    but overclocking a single nehalem cpu is already quite tricky, ocing several in tandem will be quite a challange... but as i said, ill check if we can do it
    Nov 2005
    New Hampshire
    I never considered that FoxxConn would do a dualie so I didn't ask.
    I use their boards in my video surveylance units and they hold up nicely.
    Here's one for you.
    Today I was in a bank where I'd installed a system over a year ago.
    PC based, Foxxconn board, P4-2660,3-320 gig drives..
    They'd moved the system into a closed cabinet
    The only openings were 2-2.5" holes for the elec wires and the cables for the 10 cameras. Those pretty much filled the holes.
    Now here I am in this air conditioned room and I open the cabinet door and it's like a wave of heat that hit me.
    Had to be close to 180F in that cabinet.
    They told me their "handyman" put it in there in January to hide it.
    I'm amazed that it didn't shutdown.
    I put in a wedge to keep the door open and taped a note to the top not to close it.
    On the memory, DDR3-1333 ECC is going to be the standard for the dual socket Gainstown systems.
    X.I.P.
    Mar 2005
    Mumbai, India
    Very interesting indeed.
    c[_]
    Nov 2002
    Alberta, Canada
    Should have made a seaburg board so we dont have to fight with asus for bioses that work lol
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
    Wuf
    Jul 2007
    Finland/Tampere
    Quote Originally Posted by STEvil View Post
    Hehe yea
    I'll wait info is this project possible and is the dual gainestown overclocking possible.
    DDR3-1333 ECC should be enought fast for anything and cheap at gainestown release
    Ze gear:
    Xtreme X.I.P.
    Nov 2002
    Shipai
    who do you think is building all the server boards for the big guys like dell?
    about the pc thing, yeah, ive heard similar stories so many times...
    the best was at cebit last year tho, enermax and some other company both build plexi glass boxes with running systems inside, without ANY holes for air moving whatsoever
    so on the second day they were busy drilling loads of holes into the plexi glass boxes
    i checked, and we can def do it... but if itll be ocable is another thing... :/
    you guys should be able to shut down ecc btw, which should give a small perf boost actually
    Wuf
    Jul 2007
    Finland/Tampere
    Neat
    Let's us know does this project go anywhere from drawning board
    Ze gear:
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    can we get 8phase digital (or more) for each cpu, and multi phase high volting power on the ram
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Jul 2007
    ARIZONA
    now yer talken
    [SIGPIC][/SIGPIC]
    PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
    FOXCONN MARS
    COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
    BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
    OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
    Quattro 1000W
    Radeon 2-4850's in crossfire
    OCZ Vertex SSD thanks Tony!
    ALL PIPED INTO HOUSE AIRCOND ;}
    *QUANTUM FORCE* saaya & sham rocks !
    *REAL TEMP*
    At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
    *MEMSET* Felix rocks !
    *SUPER TEC MAN* UncleJimbo rocks !
    OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
    Wuf
    Jul 2007
    Finland/Tampere
    Quote Originally Posted by zanzabar View Post
    Own 16 Phase digital for both Cpu and 4phase for ram
    Now we're talkin :p
    If the OCing is possible, don't for christ sake leave the vcore and other voltage controll too low
    2.3vcore should be enought
    Ze gear:
    Nov 2005
    New Hampshire
    ahh, remember, I don't look at Dell's that often..
    Now what I'd like to see in a dual is vcore and vdimm adjustments in the bios to 1.6 on the vcore and 2.3 on the vdimm
    Then a board with 8 phase power minimum, 2 banks of 6 dimm slots,onboard vid, and most important, spacing between the cpu sockets that will allow the use of top HS's.
    If the cpu sockets are right next to one another anyone that tries to use something like a TRUE is screwed.
    That's what would work for me but to make it also something that would sell to the workstation crowd( a very tough sell to those people as they are devouted SM and Tyan buyers) is adding 2-ver2.0 PCI-e X16 slots, a pci-e X8 slot , and then last a pci 32 or a PCI-X slot.
    Yes, PCI-X may be "old" but trust me, in that crowd it is still big.
    now when you build this biatch send one here and don't forget the 2-3200EE's and the 6-1 gig sticks of DDR3-1333(or 1600) ECC memory.
    I'll provide the rest..
    Jul 2007
    SF bay area, CA
    Quote Originally Posted by s0lid View Post
    Now we're talkin :p
    it uses 3 channel ram so u would need 3 or 6 phase per set, so thats 32phase digital cpu and 12phase ram for what u are suggesting
  18. #18
    Wuf
    Jul 2007
    Finland/Tampere
    Now what I'd like to see in a dual is vcore and vdimm adjustments in the bios to 2.1 on the vcore and 2.8 on the vdimm
    Then a board with 8 phase power minimum, 2 banks of 6 dimm slots,onboard vid, and most important, spacing between the cpu sockets that will allow the use of top HS's, LN2 pots and SS evaps.
    That's what would work for me but to make it also something that would sell to the workstation crowd( a very tough sell to those people as they are devouted SM and Tyan buyers) is adding 3-ver2.0 PCI-e X16 slots, a pci-e X8 slot , and then last a pci 32 or a PCI-X slot.
    now when you build this biatch send ones here and to s0lid and don't forget the 2-3200EE's and the 6-1 gig sticks of DDR3-1333(or 1600) ECC memory.
    We'll provide the rest..
    Corrected it a bit
    I'd recommend to sell this board as enthusiast board
    Ze gear:
  19. #19
    Xtreme Mentor
    Apr 2007
    Idaho
    Foxconn will make one, but for another company (Intel).
    I wouldn't be surprised if Foxconn made some self branded Nehalem DP boards as well, due to how successful the Quantum Force brand has been.
    "To exist in this vast universe for a speck of time is the great gift of life. Our tiny sliver of time is our gift of life. It is our only life. The universe will go on, indifferent to our brief existence, but while we are here we touch not just part of that vastness, but also the lives around us. Life is the gift each of us has been given. Each life is our own and no one else's. It is precious beyond all counting. It is the greatest value we have. Cherish it for what it truly is."
  20. #20
    Nov 2005
    New Hampshire
    Corrected it a bit
    I think they'd run into an issue with Intel as Intel will be making a SkullTrail II based on Nehalem.
    possible that Foxxconn will be making it for them I'd guess.
    Lets see, dual Gainstown at 4000+..on air..
    Yup, Permawood..
  21. #21
    Wuf
    Jul 2007
    Finland/Tampere
    Yup, Permawood..
    Permawood?
    Well I think the main difference would be just ST2 has SLI and Foxconns one don't and price ofc
    I don't see any problems with this anyways...
    4500+ with SS Mmm
    Ze gear:
  22. #22
    Nov 2005
    New Hampshire
    Permawood?
    4500+ with SS Mmm :ROFL:
    Permawood= wood+permanent..
    Yes, you may be right..Keep it a simple board and Intel should have no issues.
  23. #23
    Wuf
    Jul 2007
    Finland/Tampere
    I don't still get it
    Ze gear:
  24. #24
    Nov 2005
    New Hampshire
    HMM, how to explain this.
    Over here the expression "wood" means that a certain part of the male anatomy has enlarged due to large amounts of blood being directed there.
    This state usually occurs just before procreation..
    Have I know explained this in a politically correct manner?
  25. #25
    Wuf
    Jul 2007
    Finland/Tampere
    Now i got it
    Didn't get that because haven't heard that wood word were used that way
    Sry for the fuzz
    Ze gear:
