Is it possible to convert a dual DVI output into 3 DVI outputs?
Homebuilt Tripplehead 2 Go is what i'm after really.. in conjunction with the "SoftTH" software
All along the watchtower the watchmen watch the eternal return.
i would be very interested in this as well......
not sure if this is what you need but look at this from matrox
http://www.matrox.com/graphics/en/products/gxm/th2go/
Main PC
Core2Quad QX6850
Asus MAXUMUS EXTREEM
2x1024MB CORSAIR DDR3 1333 DHX
Saphire HD 5870 1000/1250@1.35v
PC Power & Cooling Silencer 750 Quad Power Supply (HD2900XT Crossfire Edition) - ATI Red
Logitech g25 wheel and shifter
Logitech g15 key board
Aquairo VFD monitor system
Logitec Z5500 sound system
The point was to avoid buying one of those.... if you bothered to read the first post.
mmmm... where to start.. well first of I reckon a looksy inside a triple-head to go would be good
plus knowing exactly is inside it as well...
I'm guessing there'd be 'an assortment' of... crap.. what do they call 'em?.. those things that are on video cards, they process the image for actual display, the final part of getting a pic on ur monitor..... I believe Silicon Image is one company that makes them..
anyone follow?
DNA = Design Not Accident
DNA = Darwin Not Accurate
heatware / ebay
HARDWARE I only own Xeons, Extreme Editions & Lian Li's
https://prism-break.org/
something along the lines of these 'things':
http://www.siliconimage.com/products...ly.aspx?id=1#1
heatware / ebay
