So here is my unit. Not all the preliminary pics are here, but thats because its already posted in a forum where nobody really knows how to do this stuff, so some of the initial "parts" pictures are not there.
Since you really cant see, the compressor is NF10FX.
Instead of building mine into a box, or directly into my case, i chose to put it on a 1/4" Alu plate (6061), its about 15" x 8". I just wanted some rigidity and something that i could thread directly into.
The Alu plate, now that it’s been cut down and the edges beveled, I can drill some holes.
As I mentioned before, I wanted to thread directly into the plate to make things tidier and use less parts. I threaded it for 1/4-20. That 1/4” inch / 20 threads per inch.
Now I must say I could have done things better with the condenser. I had planned on using some rubber grommets but that didn’t pan out since the metal was just too thick. So now I think I'll just put a thin foam pad underneath the entire thing and just use some washers to compensate for the large holes. The holes are for it are also threaded, but I can not remember what I used atm. Also, the holes had to be off center so I wouldn't risk hitting the copper with the drill bit.
This is a pic of the first copper loop I did. It was ok, but not perfect. In the end I decided to redo it since it was just not bent with all the connections to the condenser and compressor in mind.
Much better. I got some more loops (though I didn't need more) without using any more space, just moved the whole thing closer to the compressor.
Just a tiny part of the connection didn't get brazed, got fixed later.
This is where I stopped, I'm going to break the next days work into another post.
