+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 56
Thread: XS Assault.......Operation Viking.(Stats hounds please check in)
  1. #26
    Banned
    Feb 2006
    Hhw
    0
    I have two don't worry it's just that my cell reception is almost as bad I often need to walk into the garden to have a decent connection. And it's a two year plan, once it's done I'll defo take another provider
  2. #27
    Xtreme Cruncher
    Dec 2006
    Minnesota
    0
    Quote Originally Posted by vaio View Post
    Cosmology@home.-BOINC
    Current Rank 76th......vault points----8820.
    Lots of teams have slackened off on this.....a few weeks effort could easily accrue a few hundred vault points.
    Pass the Power Cows who are 20 places ahead and you would gain 315 points.
    More importantly, your nearest rivals, Team Norway are practically idle there right now.......and gain would help bridge the gap at the vault.
    Bonuses:
    A good run on this would see you pass:
    Crunchers Inc (my team)-61st.
    Anandtech-59th.
    DPC-56TH.
    and ultimately Team Norway who are 37th.
    So, you would not only add a few hundred vault points but they would be dropping points too!!!
    A top 40 place wouldn't take too long with decent support.
    Current Cosmo Stats
    This one looks like a good one to move up on. I was on it for awhile last month. It does really well with 64 bit machines. Credits are fixed per work unit. I'm willing to follow. I will be leaving most of my 32 bit boxes on Wieferich@Home.
  3. #28
    Wandersome Cruncher vaio's Avatar
    Apr 2005
    England
    0
    Why follow when you can lead?
    Someone has to set the ball rolling
    Visit The Boinc Bar Today
    Boinc Boinc......The first 50 mil is the hardest!
    POEM U.K number one.....woot
  4. #29
    Dak's Son [XC] riptide's Avatar
    Mar 2006
    Between 130 & 160 BPM
    0
    Right screw that. I'll try Poem.
    Eon uses too much BW for me. 1 gig a day? GTFO!
    Cosmology... 32bit is castrated? GTFO!
    Muon... done enough of that for a while...
    Community TSC.... hmmm ran that and not bad.
    Might try that ghastly project Poem.
    Quote Originally Posted by 3Z3VH View Post
    A fine line divides "Ghetto" and "Extreme" !
    De gustibus non est disputandum
  5. #30
    Xtreme Cruncher bullet2urbrain's Avatar
    Feb 2005
    Tucson, AZ
    0
    Quote Originally Posted by [XC] riptide View Post
    Hey what up?
    Anyone remember me? ya know the cruncher sans Special Colored name thingy..
    What project needs a Q9450???
    I prefer NON-BOINC but if i have to, I will.
    Currently have 4 instances of SoB running, just to see how it does.. its not that good.. due to low clock speed. (Stock @ 2.67 due to OEM Cooler.. for now)
    Let me know where we need help.. and I'll give atleast a week straight of near idle crunching.
    Cheers
  6. #31
    Mar 2006
    0
    Quote Originally Posted by bullet2urbrain View Post
    Hey what up?
    Cheers
    What up dude? Sob eh? What ram speed you pulln'? You'll make that Stock pull like 3Ghz if you Hike your ram speed in SOB.
  7. #32
    Apr 2005
    England
    0
    Community TSC and Eon right now for non-boinc applications.
  8. #33
    Feb 2005
    Tucson, AZ
    0
    Will start Tomorrown night on EON...
    Will run for 1 week..
    Rip: RAM is untweaked, which reminds me i should fix that
  9. #34
    Xtreme Cruncher KaptainBlaZzed's Avatar
    Mar 2005
    Houston
    0
    good luck with that, I tried to run eon last week and gave up. I was getting <2000 WUs per day with +50 clients running.
    I am running DPAD right now.
    eVGA X58 Calssified E761 | i7 920 @ 4.0GHz | 6GB Corsair 1600 | 2 x 60GB OCZ Agility 3 RAID0 | 2 x Radeon 5870
    SuperMicro X7DWA-N | 2 x Xeon X5470 @ 3.66GHz | 16GB FB-Dimm 800 | 8 x Samsung F3EG 2TB RAID6 | Radeon 5870
    MINER | 2 x Radeon 5830
    BTC Mining Calculator: 1,800 M/hashes per second
  10. #35
    Feb 2005
    Tucson, AZ
    0
    Quote Originally Posted by KaptainBlaZzed View Post
    Okay well EON = Too much BW on a slow DSL conn.
    DPAD, is there any way to run it as a client without the full screen garbage?? i still need to use my computer....
    and I dont have BOINC installed, but if those are the only projects that are straightforward and require little to no tinkering then i'll join one of those.
  11. #36
    Mar 2005
    Houston
    0
    yes, go to your DPAD folder and run client.exe this will run it in a DOS window.
    if you run background_client.bat it will run in the background and you will not see it.
  12. #37
    Feb 2005
    Tucson, AZ
    0
    Okay, well its running, i've made a User.txt file, and its going, now how do i join Team XS?
  13. #38
    Mar 2006
    0
    You put [XS] tag infront of your name like mine... '[XS]riptide'.
    Also see the DPAD thread in this section..
  14. #39
    Xtreme Cruncher Paladin's Avatar
    Nov 2002
    Denver
    0
    Wieferich@Home is non-BOINC, Windows-only, and we're very close (2.63 days) to passing the fiordians. They've started putting up a fight, so that time will increase. A pass would mean about 250 for us and the same loss for them in Vault points. So far it's just been Glenn and myself.
    Stats
    DeXter::2xXeon2.4@3200, GF6800, PC-DL, 1gb Centon, IWT+panaflo air, Win7
    Quad::Q6600(g0)@3400(1.30V), GTX275, 965P-DS3, 4gb HyperX, Asus SilentSquare (air), Win7_64U
    NuQuad::Q9400@3300(1.24V), 8800GT, G31M-ES2L, 2gb Patriot, stock air (bigger Q6600 one), WinXP64
    Crunch::E4300@2400, onboard, GF7100PVT-M3, 2gb Patriot CL5, stock air, Vista64U
  15. #40
    Mar 2006
    0
    Quote Originally Posted by Paladin View Post
    Stats
    Hmm. You'll be joined by in that case.
  16. #41
    Mar 2006
    0
    Hey! How does this work on quadcores? Seems limited to dual cores for the multi core launcher.
    Ah yes. Change Launcher.ini to read core=4
  17. #42
    Xtreme Cruncher
    Dec 2006
    Minnesota
    0
    Our team members have doubled on Wieferich today . Looks like we're gonna have a little fun.
  18. #43
    Feb 2005
    Tucson, AZ
    0
    having system instability.. not sure why, working to get stable to help out wiht DC Projects, will join on Wieferich if i can get stable.
    computer is just randomly hard locking, not even resetting just hardlocking on the desktop.
    trying to straighten this out... any advice would be good.
    Q9450
    Gigabyte P43-DSEL
    2 x 1gB of Team 667 3-3-3-8 @ 2.0v BIOS (D9GMH)
    XFX 9800GTX
    PCP&C 610W Silencer
    1 optical, 2 HDD's
    anything to check for, im still gathering info about the BIOS and stuff.. downloading OCCT and wPrime as I type
  19. #44
    Mar 2006
    0
    Hardlock very often means RAM/NB issue.
  20. #45
    Mar 2006
    0
    I'm having issues with getting the stats in my Free-DC statstool sig. I used 469 as the number, according to Free-DC it was my CPID when i clicked on my name in the team listing.
  21. #46
    Nov 2002
    Denver
    0
    That info is in the place that shall not be named...
    I agree with Riptide, likely RAM issue. Raise volts or timings?
    When I look at your name is says 0811194445B1. I think if you convert that back from hex to ascii it would be "Awesome".
  22. #47
    Mar 2006
    0
    Worked.!! I must add, these points are hard to come. Relatively long tests etc. Not exacltly shooting fish in the barrell lol. But whne the other machines starting calling home we'll see a nice jump. I see the Norway are making a foray.
  23. #48
    Mar 2006
    0
    OK. Whats the comparison like? What CPU's get what? OS? Cos I ain't getting a lot of scores and I have 19 cores on this now. Also its seems to have mixed up my chips entirely in the CPU ID. it either says its a 3420Mhz or a 4005Mhz. SOmetimes this differs across the same machine on 4 instances. lol
  24. #49
    Xtreme Cruncher
    Dec 2006
    Minnesota
    0
    I currently have 20 cores running and getting around 950 points. Should get around 50 points per day per core for a overclocked Q6600. 6 of my cores are AMD and 14 being Intel Core 2. Each core shows up in my CPU list at:
    http://www.elmath.org/index.php?id=d...r=0623223154C4 Your CPU only shows 4 in the list. They have 2 programs to download. Did you use the one called "multicore launcher". The 1st time I started running this I had downloaded the wrong one.
    When I run on a quad I will have 4 trafic light type icons down in my running task bar. If I click on it it opens up a window. If I click on it again it closes the window. I was opening the windows via the right click method until for some time before I noticed the short cut method.
  25. #50
    Mar 2006
    0
    Yes. And furthermore I DLed the Beta version aswell. It had the same issue with the stable version aswell though. Not all the cores were visible on my page? I htink they might have to reconnect though. I'll give it time.
+ Reply to Thread
