+ Reply to Thread
Results 1 to 25 of 25
Thread: ? about Feser Base Corrosion Blocker 50ml
    Xtreme Member menace2society's Avatar
    Apr 2008
    I'am were I'm at
    0
    Does anyone use it, and is it any good? Is PT Nuke a better product?
    TIA
    Coolermaster Cosmos S
    BenQ 241w
    Asus Chrosshair II
    OCZ Reaper HPC Edition 4GB
    Gigabyte Oden 1200w psu
    AMD Phenom 9950BLK@ 3000
    Swiftech MCP355, D-TEK FuZion v2
    Tygon B-44-4x,XSPC Dual Bay Res.
    SAMSUNG Spinpoint F1 1TB
    Radeon HD 4870 X2
    Black Ice GT Stealth 360 XFlow
    Bada Bing Bada Boom
    Xtreme Addict MpG's Avatar
    Jul 2007
    Canada
    0
    Different kinds of product entirely.
    PT Nuke prevents algae/other life from growing in your loop, while the Feser stuff prevent metal corrosion. Beyond that, I don't know what the Feser stuff is able to accomplish - if it's just supposed to be a little helping hand, or if it's actually supposed to protect against galvanic corrosion.
    i7 2600K | ASUS Maximus IV GENE-Z | GTX Titan | Corsair DDR3-2133
    Xtreme Addict kinghong1970's Avatar
    May 2007
    New York City
    2
    ya know, honestly, my simple and perhaps a dumb ass way of thinking...
    drink water...
    drink yogurt...
    which flows better?
    as i've worked with some of my previous WC'd builds for my brothers... who where anxious to get "red Coolant" "Purple Coolant" and such... honestly Distilled with Nuke and colored tubes is the way i'd go in the future...
    just my thoughts...
    "The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands in times challenge and controversy."
    Dr. Martin Luther King Jr.
    DIY: Self Clinching Nuts
    Canon EOS 7D | Tokina 12-24mm f/4 | Canon EF 24-105 f/4 L | Canon EF 70-200 f/2.8 L IS Mk II | Canon EF 35mm f/1.4 L | Canon EF 400mm f/5.6 L | Canon EF 100-400mm f/4-5.6 L
    I am Xtreme Waterlogged's Avatar
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    0
    Call me slow but....the reason for Fester's acid water now becomes abundantly clear.
    ing whores!!!
    Circles SucQ!
    I am Xtreme
    Aug 2006
    0
    I wouldn't go near Feser and I would be careful of both. Both are terribly acidic and can be downright dangerous.
    May 2007
    New York City
    2
    Quote Originally Posted by Waterlogged View Post
    ing whores!!!
    i told you it's my dumbass way of thinking...
    ha ha ha!
    Jul 2007
    Canada
    0
    Quote Originally Posted by IanY View Post
    Have there been documented cases of properly used PT Nuke causing problems? I can't recall stumbling across any issues that didn't happen because some numbnut dumped the whole bottle into their loop. Me, I've always used the 1 drop/litre ratio, never come across any suggestion of developing problems when I flush out my loop a month or two later.
    Xtreme Mentor Conumdrum's Avatar
    Oct 2007
    USA
    2
    I'm still kinda new, went water early this year but have drained/refilled many times and removed/added parts. I did have a bit of copper discoleration in my IONE after 5 months, came off with ketchup easy enuff, but never ever any buildup or issues. I use Tygon silver and a XPSC res (100mm one), which is always crystal clear inside. And I have never ever read of any issues with Distilled and PT Nuke.
    Fesser on the other hand............... or any other bling product........
    All stock for now, no need for more, but it's gonna be soon methinks.
    Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
    SLI GTX470 EVGA
    EK HF nickle blue top CPU block (free from Eddie)
    Koolance 470 waterblocks
    One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
    Banchetto Tech Station
    120 GB SSD, and a few other drives.
    1000W UltraX3 PSU, 900 watt (1500VA UPS
    23.999" Acer GD235hz and 24" Acer H243H
    I am Xtreme
    Aug 2006
    0
    Quote Originally Posted by MpG View Post
    You do pay attention to the ratio. Do you use baking soda?
    Darwin's theory has a habit of occurring from time to time. There are quite a lot of "numbnuts" around. One in particular asked if five drops is enough, and whether he should use ten drops.
    I flush my loop monthly as well. I use nothing.
    Xtreme X.I.P. Martinm210's Avatar
    Jun 2007
    Klamath Falls, Oregon
    26
    I don't know.
    All I know is I've used a combination of some sort of ethelene glycol like Hydrx or Pentosin along with two drop of PTnuke in Walmart distilled water and I've never had any sort of growth or corrsion issues. I like my PTnuke, I even throw in a drop in my testing loops when they are up for a couple of days...
    Xtreme Member tjelaw's Avatar
    Oct 2006
    Netherlands
    0
    Should it be ok to use the Feser Corrosion blocker instead of vinegar (as the sticky guide explains) to clean uit your rads & blocks? If afterwards you thoroughly flush it out with demin. water ofcourse....
    my buddy, Lian Li A70:
    * Asus P6T Deluxe & Intel Core i7 920 @ 4.2 + HT, stable @ 1.3875v & 6GB OCZ PC3-12800 Triple Channel Low Voltage & 1X Hitachi Deskstar 1TB
    * DELL 30"WFP3007-HC & 2x 4850 CrossFire & X-Fi Fatal1ty Pro & Sennheiser HD595
    * SilverStone Zeus 750W
    my liquid setup:
    *cpu EK Supreme Acrylic *rad TFC Xchanger 480QUAD *pump DDC-2 + XPSC reservoir top
    *tubing Tygon B-44-4X 1/2"ID - 3/4"OD + all Feser compression fittings
    MY LIAN-LI A70-480QUAD WORKLOG - KAOZZ.COM
    I am Xtreme
    Aug 2006
    0
    Quote Originally Posted by tjelaw View Post
    The Stickies are not updated! Whatever you do, DO NOT USE VINEGAR FOR ANYTHING EVER.... vinegar will damage your equipment! The only exception is a tiny amount of tomato ketchup to shine the surface of your blocks, but you won't have to worry about that for the first year.
    {Movieman or Vapor... please please get MaxxxRacer to change the vinegar section, or just delete that portion}
    I don't see how the Feser Corrosion blocker product can clean your radiator, but no comments there.
    If you are using a Thermochill or Swiftech or Black Ice radiator, all you need to use to clean your radiators are hot water. The flux will be cleaned with just hot water flushes. The water cannot be boiling, but must be hot.
    If you are more adventurous, you can use automotive radiator flush. You should be able to find that at any auto parts store. Again, this isn't necessary.
    I leave it to you whether you want the hot water to be fancy distilled/deionized water. I don't use fancy water for cleaning, but many people do. However, for the final rinse, you must use room temperature distilled/deionized water.
    The blocks are easier to clean. Just place them in a container with warm distilled/deionized water and gently clean them. Make sure the water is not hot enough to damage the rubber seals and gaskets.
    Cleaning should be a simple process. Just do it. Good luck.
    Xtreme Addict Zaskar's Avatar
    Feb 2008
    1
    Wait what the heck, why? Thats another thing People always recommend to do, and atleast a third here have most likely done due to it being recommended.
    EVGA X58 Classified
    Intel i7 965
    Corsair Dominator 1600mhz 3x2gb
    Nvidia GTX 295
    I am Xtreme
    Aug 2006
    0
    Quote Originally Posted by Zaskar View Post
    You are talking about vinegar or hot water?
    Feb 2008
    1
    The boiling water part.
    EVGA X58 Classified
    Intel i7 965
    Nvidia GTX 295
    I am Xtreme
    Aug 2006
    0
    Well, that part isn't science, I would admit that. There's nothing magical about 100 celcius. If you are pouring boiling water, it also not as though its any safer at 95C or 90C.
    I will admit its only a personal preference because boiling water splatters more easily.
    Oct 2006
    Netherlands
    0
    IanY thanks for the advice, I allways just went along with what the stickies said. I had just put the copper part of my supreme block into some vinegar, I came to my computer, hit F5 .... ran back to the kitchen, dumped everything into the sink and flushed with water maniacally, sort of.
    Should be no permanent damage I guess, thanks again. I think my block is clean will start on the rad now
    my liquid setup:
  18. #18
    I am Xtreme
    Aug 2006
    0
    Great! No damage to the block. There were guys who took the vinegar thing really serious. They left their blocks in for hours.. one guy for three days. You can only imagine the blocks.
  19. #19
    Jun 2007
    0
    Quote Originally Posted by kinghong1970 View Post
    ha ha ha!
    Well, My statement was more about Fester's water being an acid and the product in the title of this topic being used to "neutral" said water out.
    +1
    While I agree with everything IanY has said in the above post, I can not agree enough with what's been highlighted. Please......Remove the vinegar! .....and while your at it, put "FTW" on the banned word list please.
    Circles SucQ!
  20. #20
    Feb 2008
    1
    Why is their liquid technically an acid? Is it their way to try to prevent growth by making the water a PH that nothing wants to grow in?
    EVGA X58 Classified
    Intel i7 965
    Nvidia GTX 295
  21. #21
    I am Xtreme
    Aug 2006
    0
    Its not just technically an acid. It has a pH of 2.0. That's almost catching up with sulphuric or hydrochloric acid. It kills everything in its path. Unfortunately, that includes the water block as well.
  22. #22
    Jun 2007
    0
    For that answer, you'll have to ask Fester. Their site specifically states
    Feser Aqua has to first of all passed through the reverse osmosis system, and shortly after this into the downstreamed De-Ionized system. The PH-Value is 2.0 – 3.0 and lies in the acid ph-range.
    Pffft, It's not even distilled.
    Circles SucQ!
  23. #23
    I am Xtreme
    Aug 2006
    0
    I bet Tropicana orange juice doesn't have a pH of 2.0.
  24. #24
    Feb 2008
    1
    EVGA X58 Classified
    Intel i7 965
    Nvidia GTX 295
  25. #25
    I am Xtreme
    Aug 2006
    0
    woah.. 110 calories per serving. Is there a Diet version?
+ Reply to Thread
