Hi everyone, me again.
After tinkering around with the prototype (of the circuit defined in #43) under various load conditions i found that it isn't quite stable under low load conditions. For those of you that want to try undervolting your peltiers down to lower levels (like say 50% or 30% of vmax) the converter might not regulate properly. I find that it goes to an unstable "hiccup" cycle.
I found that by chucking out the synchronous mosfets and increasing the size of the schottky stability can be achieved even for very low load levels.
The snag with this approach:
Converter efficiency suffers. The schottky must be heatsinked. So much for my requirement that this was fanless...
now i think that with better (I.E. more expensive) circuitry that it might be possible to build a unit that works at both low power levels and still be fanless at high power levels.
What design criteria would you guys want in a converter? Fanless? or cheap?
Personally, i'm thinking that since ALL TEC setups must have great cooling they must also have great fans, I could design the converter layout so that its easily mountable behind one of the fans already used for TEC cooling. Since the converter can operate even at 70 degrees it can be mounted on the "exhuast" side of the fans and therefore incur no penalty to system cooling. Snag is that some people might think it looks UGLY.
On a different note: I've been taking pictures of my progress, should i post those here? or in a new thread so i don't clutter the crap outta this one?
