i see your point.
if you scroll up to post #40, i have a temperature contol circuit. It is still directly compatible with the newer converter. Its manually controlled, but once set will continually adjust power to achieve constant temperature cooling.
advantage is that even if something weird happened to your computer the temperature controller is independent and will continue to function. If you externally power the circuit then it'll give you control even when the computer is off.
Disadvantage ofcourse is that its not elegantly computer controlled
I'll design the fan header tonight. I should have a viable circuit by tomorrow.
Quick question though, do you already have power supply for your TEC? If so, it might be MUCH cheaper to go with Uncle Jimbo's controller. My converter has the voltage boost function which is why its so expensive. Uncle Jimbo's controller only cuts voltage, it doesn't boost it. If you already have a power supply then that might be the cheaper option. However his option is not fan header controlled.
I can still design for you a fan-header controller without voltage boost. you just insert it into your current TEC power supply. And it would be simple enough for you to build yourself.
