Looks like Sharka has just about everything I would need as well, they've got 6mm ID tubing and compression fittings as well as 8mm so there is that option. The only thing they don't have that i would normally get is the Swiftech Rad...I'd have to go back to the Black Ice GT Stealth which sounds like a more restrictive rad.
The thing that has me wanting to "settle" for the Black Ice rad and order from Sharka is they've got black 6mm ID tubing which I think looks freaking sweet and it's pretty cheap as well. If I did want to go with 8mm ID tubing and 1/4" compression fittings there is Tygon 8mm ID tubing that's clear and would work great, but it's about 4 times as much and I really like the look of the black tubing.
Honestly...because I'm not insanely worried about temps (as long as they're as good as/better then my air temps by even a small margin) I think I wanna stick with the 6mm compression fittings so I can get the black tubing. I'm gonna be tearing the Shuttle apart to get the interior of the case painted black and sleeve the PSU cables black before the watercooling gets installed and I just think that the black tubing would be too perfect.
It's because I'm doing/planning a lot of this based on aesthetics that I'm probably gonna have some people trying to change my mind, but (like i said) if my temps are even 5C better then my air temps I'll be satisfied enough, because I wanna do all this to reduce noise and to create a system that makes you stop and stare.
I'm gonna be constantly looking for ways to improve the setup as i might not get to start buying things for a month or so but please don't let that stop any of you from commenting on the plans or suggesting new/different ideas.
