It's actually quite easy for me to order 6mm and 10mm compression fittings and waterblocks with compatible G1/4" threads...performance-pcs carries the Bitspower compression fittings I would need/want and there are tons of waterblocks/pumps/rads that support the G1/4" thread...here's what I'm looking at so far:
Swiftech Apogee GT Extreme CPU block
DangerDen CPX1 Compact Low Noise Pump
Black Ice GT Stealth 120 Radiator
Bitspower Premium G1/4" High Flow 1/4"ID Compression fittings x 8
Koolance Drain Valve
Blue PVC 1/4" Tubing
There's probably a little bit of explaining in order to get my point across in regards to a few parts. The CPU block I thought was a fairly good one, and I need something with a fairly basic mounting plate, as i will have to make my own or drill holes into the existing one to match the mounting holes on my Shuttle's motherboard that are not standard distances apart.
The Pump still seems to have very good max head compared to other pumps of similar size and I need something as compact as possible, as it's gonna be sitting ontop of the PSU in the empty space shown
here.
The Radiator also has to meet certain size restrictions, it has to be 40mm or less in thickness, and the Black Ice GT Stealth was (I thought) the best performing rad within those size constraints when I was looking at over a dozen last night.
The Bitspower fittings are fairly self explanitory along with the tubing. I know people are going to try and get me to go with 3/8" and it's what I would normally do as well, but within the space contraints of the Shuttle I really need all the flexibility I can get when it comes to the tubing. Check
this out to see what I mean. Kind of a bad picture but the CPU block will be behind the 92mm fan in the front of the picture, the hard drive in the bottom 3.5" bay and the radiator and 120mm fan above the drive. Just shows how little space there really is, the 6mm tubing is more of a requirement in my eyes then a convenience option.
The last part I'm fairly excited about is the
Koolance Drain Valve. I'm gonna have it mounted in the back of the case where the two rear 60mm fans are with the drain nozzle sticking out the back of the case. I'll probably setup a T-line just before or after the Drain nozzle to fill the system, and draining will be as simple as tilting the Shuttle on it's back and opening the drain valve.
One thing that I didn't include in the parts list is a GPU block. I'm still trying to figure out how it would work out, but I'd like to also put my HD4870 in the same loop with the CPU. I know normally would start yelling not to put the Q6600 and HD4870 in the same loop with only a 120.1 rad but the CPU is currently loading at 60c and the GPU at 80c on air...I doubt temps would be any worse then that if they shared that rad. As long as my CPU doesn't load at 60c and the GPU doesn't hit 80c I really don't care what the temps are like...I don't plan on dong a lot of extra overclocking with this setup, it's mainly to eliminate fans and noise in the system (and obviously for the impressive look of a watercooled Shuttle)...lower temps are more of a bonus. If I do choose to add the HD4870 to the loop I'm not sure if it'll be a GPU only block or full coverage but that's neither here nor there...just a future possibility for me to ponder for now.
I dunno how easy it is to visualize all this but after spending a few hours last night measuring things out I'm positive all this would work. The hardest and most involving part will be making a mounting plate for the Apogee to match the holes on the Shuttle mobo...but once that's done I'll be laughing!
I'm completely open to suggestions when it comes to the block/pump/rad. If something is suggested that doesn't meet measurement requirements I'll let the poster know but otherwise I'm very open to discussion...the more input the better as it'll be a little while before I can start work on this.
All the input thus far has been appreciated...keep it comin'...just remember that everything has been chosen up to this point for very specific reasons and I might not be TOO flexible to change my plans beyond a less restrictive CPU block
