Results 1 to 7 of 7
Thread: Thermaltake failures, need pictures of cracked acrylic tops.
    Sep 2007
    Mesa, AZ USA
    I know I have seen the pictures of peoples cracked acrylic tops on their Thermaltake water blocks and I have read the stories as well.
    I have recently noticed that someone in a forum I frequent is running a Thermaltake kit on a new build and low and behold there it was the infamous acrylic topped CPU block starring back at me.
    I'd like to be able to link this post so that this person I consider a friend can see for himself what he possibly has in store. Please share your pictures and stories of any failures Thermaltake related.
    Oh and just so you know I have tried the search function like any respectable forum user should, however a search does not seem to narrow things down enough to be of any real use.
    Thanks,
    Brian
    Abit AW9D-Max 975X
    Lapped E6400 @ 3.2GHz
    2gig's Corsair 6400PRO
    HD3870 512 @ 877/1251
    PC P&C Silencer 750 PSU
    Logitech G15 & G5 laser
    NZXT Lexa case
    Water Cooled
    Sep 2007
    Mesa, AZ USA
    Quote Originally Posted by RealRedRaider View Post
    try searching google images......
    Thanks for the tip, found a post with pictures over on the notebookreview forums from the one and only DarthBeavis.
    Abit AW9D-Max 975X
    NZXT Lexa case
    Water Cooled
    Wanna Pull My Finger?
    Sep 2007
    Oklahoma
    I don't think my TT block will have that problem...............
    Donate to Xtreme Systems!
    Now Showing:
    Gigabyte x48-DQ6, Q6600,OCZ 1066 Reapers,2 750gb seagate 7200.11 hd, BFG 8800GTS 512,PC P&C 750 Quad psu, 24" Sceptre lcd, Antec 900
    my wife's system now!
    Intel C2D 6400, Zotac Matx mobo, 1gb kingston mem, Nvidia 7050, I Feel really Good now!
    Jon C2D 6600 Zotac mobo 1gb mem............................................... ................. HTPC qx6700@3.0ghz
    Annabelle Amd 3800+@2.4ghz, Biostar mobo, 1gb ocz pc4500 beta's................. Optyx2 opty165@ 2.1 ghz
    'Want a real high?
    Come crunch WCG and you'll feel like your on QuadCaine"
    First loops are like first sex, all hands and thumbs till you figure out what goes where, then it's what ever works best for you.
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Quote Originally Posted by fart_plume View Post
    http://i223.photobucket.com/albums/d...e/DSC01240.jpg
    You cheated
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Sep 2007
    Oklahoma
    isn't that what your supposed to do if your extreme?
    Now Showing:
    'Want a real high?
    Mar 2008
    川崎市
    I had a thermalcrap wc kit years ago, back then when I lived in a small country where there where no alternatives (other than overpriced importing).
    that was in socket a days, so the "performance" of the tt crap was actually enough to cool the cpu, atleast for a week, then the pump was dead.
    of course tt used smaller tubing so no other pump was compatible, went with proper wc cooling from that point on up to last year where I moved to a different country, since then I've been using air (stop yelling traitor, I'm allready back into the wet thing, bunch of ek blocks allready at home).
    Besides the failed pump, the fan was atleast 3 times as loud as they claimed, TT is almost as bad as Silenx when it comes to lies about fanspec's (the almost is only there because tt fans atleast dont blow up).
