Seems that there is some kind of problem
http://foldingforum.org/viewtopic.php?f=24&t=4242
You've stability issue or something...?
PM sent...
...maybe we could help? Well, but I don't have ATI cards folding and just have folded couple of days with nv...
Please also post in the Folding Forum when fixed, or if you need help. Thanks.
Stability issue? None that I'm aware of. How bizarre. What exactly is an EUE issue? Thanks for the heads up Sc0.
Furthermore, I just tried posting in that topic on the F@H forums and it won't let me. Maybe 7im will venture back this way eventually.
I'm rather proud! It's not every day I can inadvertently contribute to a train wreck of a server!
Don't feel that bad... there were others on the business too
Have changed something this week on your machine, clock, drivers, anything? Or has weather been exceptionally hot... reasons for the EUEs (=EarlyUnitEnd) could be numerous of course. I wish I could help, not sure I can and on top of that it's midnight here in Finland -> going to have to sleep soon
Have you checked your stats recently? Looks amazing... over 4000 wus... less than 9000 points at this month. It should have got you worried.
But this is good lesson for all of us. Got to be sure of the client, hardware etc. It has to be somewhat monitored.
EDIT: I tried to pm the Doc... not sure it gone through...
thanx for your co-operation Reznik
I thought something was odd with how much my WUs went up just in the span of a few days. I never bothered to really look into it though thinking it was my video card. I heard that the 4800 series were powerhouses so, yeah. In the last week all I changed was the drivers to the most current release. That was also the first week that I pretty much left it running nearly all day, every day.
I'm just gonna reflash the stock bios on the card and set the clocks low again until I get an aftermarket cooler. I have an HR-03, but no ram or fetsinks to slap on it afterward.
Alright, card is flashed. Do kindly unlock me so we can see if I can get back to crunching.
Good morning... I pmed Dr Pande that you should be fine again and passed your apologies to him
OK... you're off the list now. Dr. Pande asked you keep eye on these sort of issue... but actually, like I said it before, it's everyone's duty to keep the clients, machine, whatever in check
Wasn't this a good lesson. This might even lead to a better code on the client side. Look at the bright side of things...
...ooh... what did I drank with my early coffee to be so positive, monday morning and all... lol...
Fold on!
Reznik... WATCH OUT!
Last update... 7 wus - no points!
(I know I'm being PITA...)
EDIT: Seems for example ATITool could cause this crashing too...
EDIT2: do you run your client with -verbosity 9 -flag. It could yield more info for you (/us). With that flag fah-core should print more detailed log which might help us.
delete your work folder and queue.dat to clear everything , Rez... then restart the client and make sure to monitor your log file on a fresh work folder and wu ensuring you don't see any EUE's (Early Unit Ends).... if you're still seeing those in the log, then need to stop the client until you have time to sit down and figure out why it's eueing in the log (driver, oc, etc...)// once you have time to sit down and troubleshoot, just test until you can get it to run from 1%-100% and complete a wu without errors.. don't just let it run with errors, that's what caused the mishap to begin with... shouldn't take very long, just need to sit down when you have time, start the client and watch the log..
an easy way to watch the log is with fahmon http://fahmon.net/download.html
for example here's one of mine right now...
__________________
Crunching XS:WCG+GpuGrid Car RadsThe Hole-Geothermal Bong! Bong! Bong! Chill, man, chill HVC PlateHX Conversion
yeah Naja, both of mine are borked again too...
from this past hr.... log... both clients are dead in the water waiting for new wu's.. plus failing to send again...
Code:[09:28:42] + Attempting to send results [09:28:42] - Couldn't send HTTP request to server [09:28:42] (Got status 503) [09:28:42] + Could not connect to Work Server (results) [09:28:42] (171.64.122.74:8080) [09:28:42] - Error: Could not transmit unit 09 (completed July 28) to work server. [09:28:42] Keeping unit 09 in queue. [09:28:42] + Attempting to send results [09:28:42] - Couldn't send HTTP request to server [09:28:42] (Got status 503) [09:28:42] + Could not connect to Work Server (results) [09:28:42] (171.64.122.74:8080) [09:28:42] - Error: Could not transmit unit 09 (completed July 28) to work server. [09:28:42] + Attempting to send results [09:28:43] - Couldn't send HTTP request to server [09:28:43] (Got status 503) [09:28:43] + Could not connect to Work Server (results) [09:28:43] (171.64.122.76:8080) [09:28:43] Could not transmit unit 09 to Collection server; keeping in queue. [09:28:43] - Preparing to get new work unit... [09:28:43] + Attempting to get work packet [09:28:43] - Connecting to assignment server [09:28:43] - Successful: assigned to (171.64.122.74). [09:28:43] + News From Folding@Home: GPU folding beta [09:28:43] Loaded queue successfully. [09:28:43] - Couldn't send HTTP request to server [09:28:43] (Got status 503) [09:28:43] + Could not connect to Work Server [09:28:43] - Attempt #1 to get work failed, and no other work to do. Waiting before retry. [09:29:03] + Attempting to get work packet [09:29:03] - Connecting to assignment server [09:29:03] - Successful: assigned to (171.64.122.74). [09:29:03] + News From Folding@Home: GPU folding beta [09:29:03] Loaded queue successfully. [09:29:03] - Couldn't send HTTP request to server [09:29:03] + Could not connect to Work Server [09:29:03] - Attempt #2 to get work failed, and no other work to do. Waiting before retry. [09:29:28] + Attempting to get work packet [09:29:28] - Connecting to assignment server [09:29:29] - Successful: assigned to (171.64.122.74). [09:29:29] + News From Folding@Home: GPU folding beta [09:29:29] Loaded queue successfully. [09:29:29] - Couldn't send HTTP request to server [09:29:29] (Got status 503) [09:29:29] + Could not connect to Work Server [09:29:29] - Attempt #3 to get work failed, and no other work to do. Waiting before retry. [09:29:58] + Attempting to get work packet [09:29:58] - Connecting to assignment server [09:29:58] - Successful: assigned to (171.64.122.74). [09:29:58] + News From Folding@Home: GPU folding beta [09:29:59] Loaded queue successfully. [09:29:59] - Couldn't send HTTP request to server [09:29:59] (Got status 503) [09:29:59] + Could not connect to Work Server [09:29:59] - Attempt #4 to get work failed, and no other work to do. Waiting before retry. [09:30:45] + Attempting to get work packet [09:30:45] - Connecting to assignment server [09:30:45] - Successful: assigned to (171.64.122.74). [09:30:45] + News From Folding@Home: GPU folding beta [09:30:46] Loaded queue successfully. [09:30:46] - Couldn't send HTTP request to server [09:30:46] (Got status 503) [09:30:46] + Could not connect to Work Server [09:30:46] - Attempt #5 to get work failed, and no other work to do. Waiting before retry. [09:32:19] + Attempting to get work packet [09:32:19] - Connecting to assignment server [09:32:20] - Successful: assigned to (171.64.122.74). [09:32:20] + News From Folding@Home: GPU folding beta [09:32:20] Loaded queue successfully. [09:32:20] - Couldn't send HTTP request to server [09:32:20] (Got status 503) [09:32:20] + Could not connect to Work Server [09:32:20] - Attempt #6 to get work failed, and no other work to do. Waiting before retry. [09:35:12] + Attempting to get work packet [09:35:12] - Connecting to assignment server [09:35:13] - Successful: assigned to (171.64.122.74). [09:35:13] + News From Folding@Home: GPU folding beta [09:35:13] Loaded queue successfully. [09:35:13] - Couldn't send HTTP request to server [09:35:13] (Got status 503) [09:35:13] + Could not connect to Work Server [09:35:13] - Attempt #7 to get work failed, and no other work to do. Waiting before retry. [09:40:39] + Attempting to get work packet [09:40:39] - Connecting to assignment server [09:40:39] - Successful: assigned to (171.64.122.74). [09:40:39] + News From Folding@Home: GPU folding beta [09:40:39] Loaded queue successfully. [09:40:39] - Couldn't send HTTP request to server [09:40:39] (Got status 503) [09:40:40] + Could not connect to Work Server [09:40:40] - Attempt #8 to get work failed, and no other work to do. Waiting before retry. [09:51:24] + Attempting to get work packet [09:51:24] - Connecting to assignment server [09:51:25] - Successful: assigned to (171.64.122.74). [09:51:25] + News From Folding@Home: GPU folding beta [09:51:25] Loaded queue successfully. [09:51:25] - Couldn't send HTTP request to server [09:51:25] (Got status 503) [09:51:25] + Could not connect to Work Server [09:51:25] - Attempt #9 to get work failed, and no other work to do. Waiting before retry. [10:12:57] + Attempting to get work packet [10:12:57] - Connecting to assignment server [10:12:57] - Successful: assigned to (171.64.122.74). [10:12:57] + News From Folding@Home: GPU folding beta [10:12:57] Loaded queue successfully. [10:12:58] - Couldn't send HTTP request to server [10:12:58] (Got status 503) [10:12:58] + Could not connect to Work Server [10:12:58] - Attempt #10 to get work failed, and no other work to do. Waiting before retry.
Ok, Cool--Thanx. My Dimes hasn't been running for 2-3 days, now this.....was just wondering if its my machine....or what!
__________________
naw, just give it time.. I'm sure they'll get it ironed out... the topic is getting kinda heated over at fah forums, so I'm just gonna be patient and let it work itself out... no need to fuel the fire...
I thought this thread was about NV card until now
I had some problems with the 4850 and Cat. 8.7 on Win/xp64
It was slightly OCed (~680 from 625) and worked for days with the new (8.7)
drivers Today however I was playing around with it and installed the CCC to be
able to make a profile (to increase the fan speed) next thing I know
(after 1%) boom,boom,boom had about ~5 eue's one after another.
Luckily I was watching it so put the card back down so far so good.
The "problem" with most 4850 is the very low fan speed as it "idles" at 82C
no joke. The load goes to ~90, but it has 4 different temperatures according to
the GPUz and the highest is actually about 5-6 degrees higher then the "official"
(the one CCC shows)temperature. Go figure
Ok, well, I'm connected and working again. I didn't make any changes or anything....just restarted it again.
Thanx for the Info, Mike!
__________________
yeah we actually didn't mention which card was in question
I was looking at that page (your link) that's the reason I started
looking at this thread. Isn't there an NV card called "Akimo"
something or similar anyway looks like it's getting sorted out on the ati side (still have wu's cued up on my gt)
EDIT**
8800gt "AKIMBO" thats the name
http://www.ncix.com/products/index.p...nufacture=eVGA
mine just went back online too they were only down for about an hour and a half this time... I just let them run and they picked up on their own when the server was avail.... the queue send failed again, but they were able to grab new wu's and start crunching again....
Code:[10:12:57] + Attempting to get work packet [10:12:57] - Connecting to assignment server [10:12:57] - Successful: assigned to (171.64.122.74). [10:12:57] + News From Folding@Home: GPU folding beta [10:12:57] Loaded queue successfully. [10:12:58] - Couldn't send HTTP request to server [10:12:58] (Got status 503) [10:12:58] + Could not connect to Work Server [10:12:58] - Attempt #10 to get work failed, and no other work to do. Waiting before retry. [10:55:53] + Attempting to get work packet [10:55:53] - Connecting to assignment server [10:55:53] - Successful: assigned to (171.64.65.20). [10:55:53] + News From Folding@Home: GPU folding beta [10:55:53] Loaded queue successfully. [10:55:54] + Attempting to send results [10:55:54] - Couldn't send HTTP request to server [10:55:54] + Could not connect to Work Server (results) [10:55:54] (171.64.122.74:8080) [10:55:54] - Error: Could not transmit unit 09 (completed July 28) to work server. [10:55:54] + Attempting to send results [10:55:55] - Couldn't send HTTP request to server [10:55:55] (Got status 503) [10:55:55] + Could not connect to Work Server (results) [10:55:55] (171.64.122.76:8080) [10:55:55] Could not transmit unit 09 to Collection server; keeping in queue. [10:55:55] + Closed connections [10:55:55] [10:55:55] + Processing work unit [10:55:55] Core required: FahCore_11.exe [10:55:55] Core found. [10:55:55] Working on queue slot 00 [July 28 10:55:55] [10:55:55] + Working ... [10:55:55] [10:55:55] *------------------------------* [10:55:55] Folding@Home GPU Core - Beta [10:55:55] Version 1.06 (Mon Jun 23 10:53:13 PDT 2008) [10:55:55] [10:55:55] Compiler : [10:55:55] Build host: amoeba [10:55:55] Preparing to commence simulation [10:55:55] - Looking at optimizations... [10:55:55] - Created dyn [10:55:55] - Files status OK [10:55:55] - Expanded 43865 -> 244433 (decompressed 557.2 percent) [10:55:55] Called DecompressByteArray: compressed_data_size=43865 data_size=244433, decompressed_data_size=244433 diff=0 [10:55:55] - Digital signature verified [10:55:55] [10:55:55] Project: 5008 (Run 4, Clone 18, Gen 68) [10:55:55] [10:55:55] Assembly optimizations on if available. [10:55:55] Entering M.D. [10:56:01] Working on 576 p5005_supervillin_e1 [10:56:02] Client config found, loading data. [10:56:02] Starting GUI Server [10:57:27] Completed 1% [10:58:51] Completed 2% [11:00:15] Completed 3% [11:01:39] Completed 4% [11:03:04] Completed 5% [11:04:28] Completed 6% [11:05:52] Completed 7% [11:07:16] Completed 8% [11:08:40] Completed 9% [11:10:04] Completed 10% [11:11:29] Completed 11% [11:12:53] Completed 12% [11:14:17] Completed 13% [11:15:41] Completed 14%
http://foldingforum.org/viewtopic.php?f=24&t=4243
Originally Posted by Vijay Pande
nice detective work scoop
The Cardboard Master Crunch with us, the XS WCG team
Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
