still working on getting the res sealed i grabed the wrong barbs at the HW store but didnt feel like getting more so i just used more silicon on it to try and seal it into the tube
Your pump orientation is not a great idea. It needs to be below the reservoir to deliver water to your pump. Plus your aiming the pump the wrong way as well and should never be trying to suck water into the inlet which you got aiming straight down. Just a heads up before you burn out your pump trying to fill the system.
Agreed, why not mount the resevoir where you have the pump now, and the pump roughly in the area you have the res?
Desktop: E8400, DFI Lanparty Jr P45-T2RS, 4GB Ballistix, XFX 9800GT, 640GB, Samsung 2232BW, V-350B
Notebook: HP Pavilion DV5-1009TX, T9400, 4GB DDR2, 9600M GT, 320GB 7200rpm, 1280x800
PROJECT .:BLACK:. Watercoold SFF build
Looks good, You should shorten the tube on the pump though or put the res where you had the pump.
see you redid the res, Can I ask why you didn't just buy a res?
BTW, pumps like having the res right before the intake. That way there's always a supply of water... You've got the res attached to the outlet. Not the best config.. Just swap the inlet and outlet of the pump. You can rotate the pump so that the inlet is looking straight up. and the oulet is pointing directly at the rad. That will also help you get air out of the loop, and out of the cpu block.
So, your looking at
Res->Pump->Rad->CPU->Res
Again, just swap the inlet and outlet of the pump. and your system will be much better. Your loosing all kinds of pressure trying to force water through the res to get to the cpu.
Looking good. I'm sad to see that ghetto res go![]()
tap the outlet at the bottom of the res and place the pump just bellow it.
It will look and work much better. That tubing curve is not looking good.
My Lian Li G70
Asus P6X58D-E * i7-930 * Saphire 7970 * 6GB Corsair XMS3 1600 C7 * Crucial M4 256GB SSD * Lian Li G70W Powdercoated
Watercooled by single loop Coolgate Quad 120 + Swiftech MCR220 with San Aces H1011 * EK Supreme HF * Koolance VID-AR797 * EK Asus X58 full set * DDC 3.25 with EK Dual Top/Res
pump to that ghetto res to cpu?? whaaa....
PTS,NCIX,PPCS *recommended*
- "Illusive Perceptions" - July-August 08 -
DFI LanParty UT->SLI
X2-3800 LCBIE 0618EPMW / AS5 / IHS Removed
EVGA 8600GTS SLi ! w/ FuZion GFX rev2
OCZ PlAtREV2. 2GB TCCD's | X-FI XTREME-FATALITY
CM 600W DUO | DD WaterWOODbox MODDED
UV1/2"LRT tubing.TDX Lapped.BIP120.2,yateLoons,
ddc.2+petras top, dd dfi nb block, dual uv
i agree with others that the order is counter intuitive, but at least you diy the res. most people just buy all their stuff toss it in a rig and call it worklog. making your own stuff is how pc's get personalized
phill
its good start,but try to change "reservoir" with a true reservoir,this is a fake,make a profi job.
rampage 2 extreme asus
i920 D0@4.2ghz apogee gtz easy lapped
zotac gtx 480 on mcw60r
3x 2048 kingston hyperx t1 2000mhz@1,65v
samsung 223b sata
2x wd 1tb 64mb cache sata2
x-fi fatality champion platinum
cm silent m pro 850w
cosmos s cooler master
dell 2209wa s-ips
z5500 digital coaxial
g9x,g15 v2
ok i looked at the stuff what a stupid mistake i just wasn't thinking when i connected the pump and did it backwards easy fix though
it was going to have a heatercore in it but i couldn't find a easy way to sway the 3/4 fitting to a 1/2 so i could get some tubing on it. but its measured and ready to swap in as soon as i sweat a proper fitting onto it
what difference will having a "true" res make its a 500mL res jus like the ones you buy made of the same stuff as everyother res why spend $50 on something that cost $6 and 20min to make?
Yeah.. those "ghetto" res work wonders.
= $45
or= $6
i7 920 on Gigabyte UD5 X58
Mugen 2
Seagate 500gb. 7200.12 + Seagate 750Gb 7200.11
Samsung LN40A650 - GTX260
Samsung sh-203n
Cruial D9JNM 2 x 3gb 2100mhz
7 ultimate 64
All housed in custom painted Coolermaster stacker 832 powered by Silverstone's DA 800
Does not look good, try to solve that tight curves on your tube. Congrats for your efforts.
My Lian Li G70
