Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: BlackOps_FSB 595MHz.NB. air cooling
    Aug 2007
    ROMA Italy
    Blackops and E8600 595FSB NB. air cooling
    Bench Table By Dimastech.
    Cascade Rotary(1,7CvX2) By Dimastech.-110
    CPU.E8600ES 814A527
    MOBO.Foxconn BlackOps Bios G27
    RAM.Cell Schock DDR3 14400 D9GTR.
    VGA.ZOTAC 9800 GX2
    PSU.Ultra X3 1600W
    Vcore.1,77v
    PLL.1,508V
    VTT.1,275v
    VNB.1,62v
    VDIMM.2,044V
    E8600@5854MHz. 1,77v.3DMark01_NO TWEAKER NO MIPMAP.
    E8600@5950MHz. 1,79v.CPU.Z VALIDATION
    E8600@5854MHz. 1,77v.AQUAMARK_3
    __________________
    Dec 2004
    Switzerland
    Very nice Results !!! So i also have to tray my E8600 on the BlackOps ! FSB looks very good !
    Regards
    splmann
    www.ocaholic.ch
    Aug 2007
    ROMA Italy
    Thanks Splmann your E8600 and commando is fantastic setup.
    Dec 2004
    Switzerland
    Old Style OC !!! But i also wil Test the BlackOps i hope it is possible to do FSB600 !
    Regards
    splmann
    www.ocaholic.ch
    Aug 2007
    ROMA Italy
    my future test is 600fsb., my friend Zilla 615FSB benchable 3D.
    Jul 2007
    ARIZONA
    thats great ! you guys get that BlackOps ironed out cause eyema getten one soon
    [SIGPIC][/SIGPIC]
    PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
    FOXCONN MARS
    COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
    BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
    OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
    Quattro 1000W
    Radeon 2-4850's in crossfire
    OCZ Vertex SSD thanks Tony!
    ALL PIPED INTO HOUSE AIRCOND ;}
    *QUANTUM FORCE* saaya & sham rocks !
    *REAL TEMP*
    At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
    *MEMSET* Felix rocks !
    *SUPER TEC MAN* UncleJimbo rocks !
    OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
    Dec 2007
    Lost and Confused in the City of Rain
    That is amazing! I really want to achieve something similar with mine!
    Jan 2006
    Dayton, OH
    MARCO74, can you post full BIOS settings, volts, volt ref., timings etc.?
    Xtreme X.I.P.
    Nov 2002
    Shipai
    wow, and so low vtt and pll! :0
    very nice!
    i talked to one of our bios engineers 2 days ago and he said he thinks he can tweak out 20more mhz for the fsb with the next BIOS release
    ill let you know once its done!
    should take a week or so though since hes working on P45 atm
    Aug 2007
    ROMA Italy
    Very nice I love Foxcon BlackOps 20Mhz+ is fantastic mobo
    Xtreme X.I.P.
    Nov 2002
    Shipai
    glad you like it
    ill pass it on to the engineers, they are always happy to hear feedback
    Jan 2006
    Dayton, OH
    Im not sure how this stacks up to the rest of the dual cores on this board with all air cooling, but this by far exceeded my exceptions after what I had heard
    Vcore: 1.4825v BIOS selected, 1.46v real
    Vpll: Stock
    Vnb: 1.5v BIOS selected, 1.52v real
    Vdimm: 2.155v BIOS selected, 2.16v real
    CPU cooler: TRUE 120 w/120mm Delta
    NB cooler: Stock w/92mm fan
    RAM cooler: 120mm Delta
    Please don't mind the time, this is no tweak at all, just testing the combo out
    Jul 2007
    ARIZONA
    niceeeeeeee
    [SIGPIC][/SIGPIC]
    FOXCONN MARS
    Quattro 1000W
    *REAL TEMP*
    Xtreme X.I.P.
    Nov 2002
    Shipai
    congrats filmbot!
    what vtt was this with?
    Aug 2007
    ROMA Italy
    Hello my friend Marco@74 and Wasky. 600MHz. NB.air cooling 600MHz.
    Jul 2007
    ARIZONA
    them ES samples just gotta be fun city to play with !!
    [SIGPIC][/SIGPIC]
    FOXCONN MARS
    Quattro 1000W
    *REAL TEMP*
    Jan 2006
    Dayton, OH
    Quote Originally Posted by saaya View Post
    congrats filmbot!
    Vtt is 1.35v BIOS selected. Also, I rushed this screeny but rams can also do 6-5-5 at the same speed and settings, http://i210.photobucket.com/albums/b...-5tighttim.jpg
    Working on getting PL to 7 right now without using too much vNB, if I have to go above 1.6v, I'm not going to bother right now. After that, I'm just going to start lowering volts till everything is still stable, then its on to air benching to prepare
    EDIT:
    Also, saaya, is there any advice so I will be able to run the 1:3 and 1:3.2 divider? I'm having problems getting those to run. Also, just some advice to guys, I kept getting stuck on code 50 and it would sometimes randomly pass, but as soon as I unplugged my external HD, everything is fine now.
  18. #18
    Xtreme X.I.P.
    Nov 2002
    Shipai
    code50 us final usb initialization, so that makes sense
    look here for postcodes:
    http://www.xtremesystems.org/forums/...d.php?t=190952
    and filmbot, did you meassure vtt? since its 45nm it should be only 1.25v vtt real :o
    very nice!
    i really regret not having had the time to play with our 8600 samples
    about the dividers hmmmm, well they should work with the right strap, but the problem is that when you use the strap jumpers on the board, they seem to lock out all the overclocking options :/ But you can give that a try, use the jumpers to force a different strap and check if 200 266 333 or 400 allow you to use the 1.3x dividers.
    somebody reported earlier that they do work with a cpu/memory combo.
    it could also be affected by the SPD of the memory, so you can try different spds on your memory.
    techpowerup has a database of spds, and typhoon burner offers a free zip collection of spd files for download, and i posted micron 1066 reference spd files in the guides and tweaks section.
    if you use a 266fsb cpu or force the 266 strap, in combination with a ddr3 800 spd profile, you should be able to use the 1:3 divider
    if you use a 333fsb cpu or force the 333 strap, in combination with a ddr3 1066 spd profile, you should be able to use the 1:3.2 divider
    if the jumpers dont work, then you could try a pin mod using silver paint on the back of the cpu to connect some pins to make it recognized as a 266 or 333 cpu
    a bit old school, and im sorry it doesnt work from bios like it should, but if you wanna do it quickly this is how you could do it right away
    congrats on 600fsb marco!
  19. #19
    Jan 2006
    Dayton, OH
    Ok, I will try the jumpers tonight, I didn't even know they were on the board
    No I didn't measure the VTT, I really didn't think about it because I don't like poking around the board I will try the reference SPDs also and see if that helps.
  20. #20
    zalman 9700NT
    Vnb 1.5 StockCooling
    CPU-Z Validator 2.1
    stay tuned
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
  21. #21
    Jul 2007
    ARIZONA
    hahahahaa very nice like the bios says Keep pushing
    [SIGPIC][/SIGPIC]
    FOXCONN MARS
    Quattro 1000W
    *REAL TEMP*
  22. #22
    and i answer him tomorrow and he will say me GOD LIKE
  23. #23
    Jul 2007
    ARIZONA
    [SIGPIC][/SIGPIC]
    FOXCONN MARS
    Quattro 1000W
    *REAL TEMP*
  24. #24
    -100c Club
    Jun 2005
    Slovenia, Europe
    very nice!
    Is this revision of the BIOS ready yet? I have an ES sample that does 545-550MHz on aircooled NB, will try to hook up single stage unit to NB.
  25. #25
    Xtreme X.I.P.
    Nov 2002
    Shipai
    hi tibor, let me check with our bios engineer
    any luck with the fsb strap jumpers? did anybody play with them?
