+ Reply to Thread
Results 1 to 9 of 9
Thread: What's up with Clearflex 60
    Xtreme Member menace2society's Avatar
    Apr 2008
    I'am were I'm at
    0
    Question What's up with Clearflex 60
    Of all the comparisons, none of them include Clearflex. Is it so bad as to not even merit mentioning
    Help me out here
    Xtreme Member Navanod's Avatar
    Dec 2007
    0
    Quote Originally Posted by menace2society View Post
    Help me out here
    I wouldn't use it again...
    stiff, kinks easily, discolors and just a pain to route
    Apr 2008
    I'am were I'm at
    0
    Quote Originally Posted by Navanod View Post
    Were are the test that provide proof. that just sounds like an opinion
    Over 70 people have read this thread and no one has done any testing?
    I have used it for quite some time now and have never used anything else. I always trying to step up my game so I'm trying to find out if I should switch and why
    Jul 2005
    1
    I don't think kinks and discoloration are opinions.
    Xtreme Cruncher CyberDruid's Avatar
    Jun 2006
    On top of a mountain
    9
    It is not suitable for the application: water causes it to fog milk white over time. It leaches plasticizer into the loop which is often confused with algae or some biologic slime. The one benefit it has is the low durmoter: it's soft. This can also be an issue for leaks though...too soft.
    I have used hundred of feet of it and am done with it...MasterKleer is far superior for our purposes.
    20 Logs on the fire for WCG: i7 920@2.8 X3220@3.0 X3220@2.4 E8400@4.05 E6600@2.4
    Apr 2008
    I'am were I'm at
    0
    Quote Originally Posted by RealRedRaider View Post
    Why test it ???
    It's so cheap, if you want to try just buy some. If you don't like it, then throw it away and buy some Tygon B44-4x...
    You assume I have some money to trough away
    Love your build buy the way.
    Quote Originally Posted by CyberDruid View Post
    Now that's what I'm talking about I have experienced white fog in the tubing that I thought was algae, had no idea it was from the tube
    Thnx Cyber I now know more then I did be for I asked the question, which is why I asked in the first place.
    What you and Coolmiester did made me go out and buy a cosmos s
    Apr 2008
    I'am were I'm at
    0
    Thanks....
    Listen to CyberDruid if you're on a budget... MasterKleer is dirt cheap....
    Took your advice and will be ordering tygon B-44-4x from Sidewinders
    Dec 2007
    0
    FYI, I've recently tested some tubings although clearflex is not one of them becos its not even worth my time to buy some to test.
    if you had read my post properly, you would see that it is more of a negative experience than just an uninformed "opinion"
    I had experienced the fogging, the kinks and the pains of trying to force it to bend to my desired angle and directions.
    There's normally no spoon, but to bite the hand that tried to feed you?
    Apr 2008
    I'am were I'm at
    0
    I was not trying to be rude nore was I trying to imply that you were uniformed. I appreciate that you took the time to answer at all I was just looking for a little more specific information. Please except my apologies for any offence taken
+ Reply to Thread
