HOWTO: 1st Gen iPhone to 2.0 Jailbreack
Ok this is a quick tutorial on how to do it, I've "just" did it to my own EDGE iPhone and its easy and it works
what you need to do is first of all download this:
http://rapidshare.de/files/40034466/...tore.ipsw.html
Its the firmware you'll need (for 1st Gen iPhones ONLY)
Then, goto iTunes and under preferences click the "forget synchronization history".
This will make sure when you sync your iPhone that iTunes makes a new backup (takes a bit longer but just to be sure ya know).
Then you needd to Power down your iPhone, and once powed down press the Home & Power key for 10 seconds, and after those 10 press the home key for 10 seconds more.
THis will bring up the image of a powercord and iTunes, directing you to plug your phone into iTunes.
Do so and once iTunes say it's found a iPhone in recovery mode SHIFT-CLICK "RECOVER" and select the firmware you just downloaded.
now just let it run its mojo (don't touch a thing)
Once everything is flashed iTunes will ask you if you want to sync the phone with the "old backup" it has of a other iPhone. Click yes and let it run for a while more (takes a long time tbh, like 10-15 minutes)
once thats done, PRESTO, congrats on your 1st Gen iPhone with 2.0 Software, unlocked & Jailbroken.
*** DISCLAIMER***
Xtreme Systems or Entity_Razer can not be held accountable for stupid thing you do or not following this tutorial. Disconnecting the cord while the iPhone is updating CAN make it stop working. We are not liable in any way or form for your actions.
Is this even allowed to be posted on here?
27" iMac
3.06GHz Core 2 Duo
8GB DDR3
1TB HDD + 2TB Ext + 1TB Ext
ATI HD 4670 256MB
20" iMac
2.4GHz Core 2 Duo
2GB+1GB G.Skill DDR2
320GB HDD
ATI HD 2600 Pro 256MB
16GB iPhone 3GS
GamerTag: ugp
GamerTag: SadisticPuppets
Well technically its not a crack or anything.
Its the official iPhone 2.0 firmware with tweaks, tweaks anyone can basically do once they instal openSSH on their iPhone so...
Does it work on the iPod Touch?
Main Rig
AMD Athlon X2 3800+ @ 2.8GHz (10x 280MHz) | ABit Kn9 NF4 | 4GB GSkill DDR2 - 800MHz | ATi Radeon HIS HD3870 | 530w Hiper Type M PSU
80GB Western Digital SATA300 Boot Drive | 500GB Western Digital SATA300 Storage Drive | 400GB Western Digital SATA300 Storage Drive | 400GB Seagate Barracuda UDMA IDE Storage Drive | 200GB Samsung Spinpoint UDMA IDE Storage Drive | 160GB Western Digital SATA300 Storage Drive
Windows Server 2008 x64 | Dual Screen: 20" TFT @ 1920x1080 | 19" TFT @ 1440x900
Media Streaming Rig/Spare PC
Intel Pentium 4 @ 2.8GHz | Generic Motherboard | 768mb Kingston DDR - 400MHz | ATi Radeon 9250SE | 350w AOpen PSU
20GB Western Digital IDE Drive
Windows XP Professional x86 w/SP3 | TV/Monitor @ 1920x1080
Entertainment Centre
40" Sony Bravia @ 1920x1080 | Sony Playstation 3 | Microsoft Xbox 360 (RED RING OF DEATH)
no, this is the iPhone frameware.
I think it'll work if you have the iPod Touch frameware thats costumized, but this frameware WILL NOT WORK
Damnit...
Next idea then...
Main Rig
- You may not post replies
- You may not edit your posts
Forum Rules
