Is the Boreas Tec cooling system powerful enough to cool quad core 2.66 GHZ?
http://www.coolitsystems.com/index.p...=52&Itemid=160
Is there any review of this product?
I would just get a few TEC blocks, a few meanwells, and a regulare w/c systeam and setup your own, I hear the coolit systems are good for a mild oc and idle teps but loads they go crazy and high ocs they get pretty toasty.
Powerful enough, yes. But the chambers use aluminum so you'll have to be ready for mixed metals, and moreover, for the same cost you "should" be able to get better temps, albeit in a slightly less compact system.
donrt have any experience with them but can recall several cases of the pump dying
"Study hard my young friend"[/B].
Woody: It's not a laser! It's a... [sighs in frustration]
eye like my COOLIT product !
it's getting better all the time with newer processors esp the 45nm
heres a link that will answer your question http://www.coolitsystems.com/
[SIGPIC][/SIGPIC]
PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
FOXCONN MARS
COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
Quattro 1000W
Radeon 2-4850's in crossfire
OCZ Vertex SSD thanks Tony!
ALL PIPED INTO HOUSE AIRCOND ;}
*QUANTUM FORCE* saaya & sham rocks !
*REAL TEMP*
At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
*MEMSET* Felix rocks !
*SUPER TEC MAN* UncleJimbo rocks !
OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
