Hi everyone, I'm in the process of trying to improve my current watercooling setup so that I can maximize my QX9650 overclock speeds and still maintain close to ambient temperatures as possible for 24/7 use and most importantly minimize things I have to do to achieve this.
I don't want to do anything extreme to my Mainboard and especially my $1000 CPU like what is required to mount a Tec Peltier setup with all that di-electric grease and having to Air and water seal the cpu socket area.
And ofcourse spending another $1000 on phase change is not an option either.
Heres what I am thinking of doing to chill water before it enters my CPU waterblock to achieve better temps.
I am gonna setup 2 watercooling loops, 1 will just be a normal watercooling setup with a cpu waterblock + reservoir + pump + triple 120mm radiator that is cooling my cpu. But now i want to add a waterblock chiller infront of my existing cpu block using a 226W Tec peltier that is sandwiched between 2 CPU waterblocks.
The cold side will be attached to the cpu waterblock that is connected to my current watercooling loop and the hot side will be attached to a cpu waterblock that is connected to a separate watercooling loop used solely to cool the Tec peltier. I have a diagram below to show how the whole thing works.
I have never used a tec peltier before and have never seen anyone use this type of setup before and am curious as to how well this will work and if it is even worth trying. If anyone here have any suggestions or advice I would greatly appreciate your input.
Oh yea here is a list of things I have and things I would need to buy to set this up.
Current Watercooling (Loop #2)
-D-Tek Fuzion V2 (Quad core insert & Water Accelerator Kit) w/ 1/2" D-Tek High Flow Barbs.
-Danger Den Dual 5.25" Reservoir
-Swiftech 655 Pump (Laing D5)
-Feser One X-360 TFC Xchanger Triple 120MM w/ DD 1/2" High Flow Barbs
-Swiftech MCW30 Chipset waterblock w/ 1/2" DD High Flow Barbs
-2 x Danger Den Maze 4 GPU Waterblock w/ 1/2" DD High Flow Barbs (SLI)
Tec Peltier Cooling (Loop #1)
-Eheim 1250 Pump
-DTek DB-1 Pump (extra pump)
-Danger Den Double Heater Core with 2 Fan shrouds, 4 X 120mm Fans in Push - Pull setup.
-Swiftech Apogee GT Waterblock (Cool the Hot Side of Peltier)
good performing block to cool the peltier.
Items I need to buy:
Loop #2
- Magicool Copper CPU Water Block (chill water from cold side of Peltier)
** I like this block becuase its cheap, and its a big square block with mounting plate that will be easy to attach to the Swiftech Apogee GT plate to sandwich the Peltier with as much pressure I want. It looks very big with alot of surface area for the water to chill before it is pumped into the CPU block.
Loop #1
- 2nd reservoir ( I don't know if I should get a Big or small or none at all cuz this is used in the loop that is used to cool the peltier.
- Power Source ( Should I get a dedicated Meanwell S-320-12 or will a good Enermax 550W with a rated 36A on the 12V rail be good enough to power the 2nd loop and the Peltier unit. I am only powering on the Peltier & loop for the chiller part of the setup when I need that extra cooling when gaming.
- Tec Peltier Unit. (I don't know anything about Peltiers or how cold and hot they get. I know that I should be getting a 50mm size cuz that is the size of the cpu waterblock surface area. But what will be cold enough and not too hot for my Dual Heater core to handle.
Also I don't know if using 50/50 antifreeze and water mix for coolant will freeze to ice and block water flow to my CPU block cuz that won't be good cuz I've already fried a motherboard before becuase I kicked loose a waterpump power connector. Funny thing was the mainboard fried from the overheating and the dual core E8400 survived. Anyways thats everything, any help would be greatly appreciated. thanks.
