This question is directed to Uncle Jimbo, but anyone with information can feel free to chime in.
I was looking at what I can improve on my setup (besides bigger TEC's) and have been leaning towards getting some new radiators. My question has to do with the conversion of watt's to btu's (using an online converter) because I am not sure if the numbers look correct. I am comparing my current radiator, swiftech 3.120 and a new DD BlackIce Extreme III. My rad has a review claiming 400 watts (I assume this is per hour) and DangerDen says the Blackice is rated at ~9700 BTU's. Now doing the conversion I see that my rad has a BTU rating of ~1366, in comparing the two can this be correct? The DangerDen rad disposes of 6x more heat? Just doesn't seem quite right and I thought I could ask someone with some experience.
I based these numbers from the swiftech rad page:
http://www.jab-tech.com/Swiftech-MCR...r-pr-3320.html
and the danger den page:
http://dangerden.com/store/product.p...85&page=1#tabs
So, if I get the new rads does this mean I will see a major improvement? I am currently using my rad to dump heat off of two tec's, one of them being ~85-115 watts on a HD3870 that is overclocked and the other tec is an unknown 50x50mm that is cooling an x6800 oc'ed to 3.4 with 1.37 V on the core. My cpu idles below zero and under full orthos load reaches around 40C after 20 minutes or so, if that is any help.
My main question in all this is whether the BlackIce radiators are actually worth the money they cost versus the cheaper radiators on the market?
Also, can someone else see if they can access the arctic spider website? It would be my luck that the time I want to order my tec from them that I cannot access their page!!
http://www.arcticspider.com/index.ph...ct_detail&p=63
Thanks in advance!!
