This is quite amazing, just so you know
The new chips also work at lower voltages than conventional chips, according to the scientists from the National Institute of Advanced Industrial Science and Technology and the University of Tokyo.
The new ferroelectric Nand Flash memory cell developed by the Japanese scientists can be scaled down to at least 10 nanometres. The next generation of conventional flash cells will use a 30 nanometre circuit density.
The ferroelectric Flash memory cell can be rewritten more than 100 million times, compared to a conventional cells lifetime of around 10,000, its inventors claim.
To prolong their life Flash memory chips use a 'wear-levelling' process in which all cells are used equally, and worn out cells are 'retired' without disabling the whole chip.
The ferroelectric cells use a rewriting voltage of fewer than six volts, compared to about 20 volts for conventional chips.
MLC can do 10.000 writes
SLC can do 50.000 writes
Source: http://www.vnunet.com/vnunet/news/22...g-life-created
