I use zip ties and a zip tie gun. I have to cut the tubing off.
Otherwise, it's compressions. I love compressions.
You will find you will not have to wait that long there are a few companies over our side of the pond seriously looking into this
Although i would say its not going to hit the market for a few month yet
WOOT! Great news!
I was browsing around and found this at aquatuning. Pretty much gonna cure Feser fever. Their 7/16" Masterkleer is dirt cheap. :P
PVC hose 15.9 / 11.1 mm UV-active blue
PVC hose 15.9 / 11.1 mm UV-active blue (transparent)
PVC hose 15.9 / 11.1 mm UV-active green
PVC hose 15.9 / 11.1 mm UV-active red
15mm (5 / 8 ")
Yeah, but that was without hoseclamps. When I'm doing pressure drop or radiator testing, I'm constantly pulling stuff apart. Hoseclamps have a nasty habity of disforming the tubing, so I've gotten in the habit of not using them. When I use 7/16" ID tubing on the test rigs, I don't have any problems, but when using 1/2" ID, I "HAVE" to at least use some zipties.
When I tested the Thermalright XWB-1 block i ran it up to 24 psi without any clamps at all using 7/16" ID tubing and not a single leak.
That's probably more pumping power than two RD-30s in series..
I can't even get the tiny db-1 (Less than 3psi) to hold pressure on the 1/2" without some sort of clamp...
Even though I'm a flow rate freak, I'll happily take the additional friction loss of 7/16"ID tubing over 1/2" ID tubing anyday...
Well Bitspower is in the process of making 7/16" compression fittings, maybe it will help the market for that tube size.
EVGA X58 Classified
Intel i7 965
Corsair Dominator 1600mhz 3x2gb
Nvidia GTX 295
I saw some generic compression fittings for 7/16" there. But it pretty much have OD size of normal 1/2" barbs. One look like Koolance.
Generic one
Look like Koolance
Nice!
As much as I didn't care to much for the compression fittings initially, they are starting to grow on me. If we could get 7/16"ID x 5/8"OD compression fittings and UV tubing, I'd be all over that..
Wow, do people like 7/16" that much?
Originally Posted by inCore
another option would be to have most mftrs that make barbs make slightly larger barbs.
Core
Core i7 920
eVGA X58 LE SLi
2x3GB Mushkin DDR3-1600
BFG 8800GT OC
Seagate 7200.12 1TB + Maxtor 320GB
LianLi A05B
Cooling (all internal)
2x BI GTS 360
2x DDC3.2 + Ek top
EK Supreme LT
I can confirm that there will be new 7/16 tubing in:
UV Blue
UV Clear/Blue
UV Green
UV Orange/Red
Black
Will be hitting the shops in the UK from tomorrow
Im sure it will be states side withing a few weeks as well
Hm, I have 5/8" barbs on my Iwaki, fitting 7/16 tubing on it will be interesting
Core
Core i7 920
eVGA X58 LE SLi
BFG 8800GT OC
LianLi A05B
2x BI GTS 360
2x DDC3.2 + Ek top
EK Supreme LT
You'll find it state side very soon as per it's XSPC who are making it:
http://www.xspc.biz/tubing2.php
It will be made in the same quality as the ½" version, which means it will be very flexiable.
Also worth noting is the Glossy Black version, which I'm personally looking forward seing
/Thomas
7/16 UV green tubing? Sweet! Though across the pond = expensive here in the USA
The Cardboard Master Crunch with us, the XS WCG team
Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
I'm gonna be changing over to 7/16" when I do re-do the loops on the Phenom and Intel rigs.... wormdrives provide peace of mind for sure, but they aren't attractive. :p
oooh, exciting.
Surely now there is 7/16" tubing, 7/16" compression fittings aren't really needed - the only reason I would buy 7/16" is because of it's tight fit on a 1/2" barb, not for the extra 1/16" of diameter?
On a normal barb that works, but 7/16" x 5/8" tubing has a 3/32" wall thickness where 1/2" ID x 3/4" ID you have a 1/8" thickness wall.
I just tried it and sure enough, the outer compression ring doesn't even make contact with the tubing, walls are too thin.
You could probably leave the compression inside portion the same, but you'd need to make the outer ring with a smaller ID to work with the thinner walls.
I was also thinking you could make the overall barb smaller to have less conflicts with tight barb spacings, etc.
Maybe after our tubing productinn can be accepted by me and then we can start for all of your needs....But there are many inquiries still on the way..
WOW! I would have never expected such crappy advice from Aquatuning. Using any other size than what the fitting is specified for is begging for trouble. If you stick 7/16" over a 1/2" barb, what happens?....it expands, meaning the O.D. is no longer 5/8", It's also not 3/4" meaning your risking either cutting the tube or a leak depending on the fitting your using.
Those are either Fester or BP's in the first link and those are Koolance in the second.
Circles SucQ!
