+ Reply to Thread
Results 1 to 4 of 4
Thread: Maximus II formula vs. P5Q Premium
    Jun 2007
    0
    I have been driving myself nuts trying to decide between the the two above boards. There is a wealth of information about the Maximus II Formula but virtually nothing about the new P5Q Premium.
    The feature set is very, very close. I like the extra USB ports and RAID options on the premium but on the other hand . . . .
    Anyone have any hands on with the P5K Premium? It seems like it has been available long enough that there should be a few floating abound out there.
    i7 920 DO 3850A849 @4410 under custom water.
    Asus P6T deluxe V2
    3X2gb Mushkin DDR3 1600 998691
    Sapphire 4870 1g
    Corsair Hx 850 psu
    2 G.Skill titan 128gb SSDs in RAID0 Data
    Intel X25-M OS drive
    Windows 7 Home Premium 64
    Xtreme Addict Alex-Ro's Avatar
    May 2007
    Romania
    13
    Go with the maximus and you won't regret
    Xtreme Enthusiast Nasgul's Avatar
    Mar 2005
    Strive for peace w/Acts of War
    0
    Go with the Maximus II.........
    Why? Well, technically you don't need extra RAID when the ICH10-R can handle up to 8 drives, you don't necessarily would need a 2nd RAID controller.
    Also, it comes with an X-Fi card, which may not mean or be a huge improvement over a PCI card by itself but at least it's not integrated.
    Premium has 8 USB ports, Maximum has 8 ports as well, except they'll take a PCI slot but it's not like you'd need one of those PCI-Ex1, so block that and you'd have 8 ports as well.
    I've looked at all the ASUS P45 boards and I'm going definitely with the Maximus II, except the Q9450 isn't $200 yet, so I'll wait till then.
    ASUS P5B Deluxe P965 BIOS 1236 | Intel Core 2 Quad Q6600 G0 8MBL2 @ 3.15GHZ | G.Skill DDR2 800 F2-6400PHU2-2GBHZ & XTreem DDR 800 D9GMH - 4GB RAM Total | 4:5 Ratio @ 350fsbx9 | Tuniq Tower 120 | BFG GeForce 9800GTX | Seagate 2x 250GB Perpendicular HDDs RAID-0 | PC Power & Cooling Silencer 750W EPS12V | Samsung TOC T240 24" LCD Monitor |
    Jun 2007
    0
    An important question for me is whether the overclocking capabilities are the same with both boards being P45 chipset.
    I have not been able to find anyone thus far who has any actual experience with the P5Q Premium board.
    Asus P6T deluxe V2
    Sapphire 4870 1g
    Corsair Hx 850 psu
+ Reply to Thread
