Why do you guys keep going back to the OCZ 4GB Ram when the Corsiar 4GB is 66 dollars...
Oh and im deff. going with quad core
Because the OCZ Perkam recommended and the G.Skill SpeedFreak recommends are PC8000/PC8500 and thus standard faster than the PC6400 the Corsair is clocked at.
Asus Sabertooth TUF Z87 - Intel Core I7-4770S - GEIL EVO Veloce 2x8GB 1866MHz - MSI R9 280X OC
Nanoxia Deep Silence 1 - Corsair AX760 - Samsung 830-128GB - Auzentech Forte 7.1
WaterKEG Extreme III - BitsPower modded MCP655 - Swiftech Apogee XT v2 - Swiftech MCW82 - Custom 280X heatsink
Dell Studio 1555: 15" Full HD screen -Intel P8600 - HD4570
2x4GB 1600MHz - Samsung 830 128GB - Backlit keyboard mod
Microsoft Surface 2 32GB - Surface Touch Cover 2
Denon AVR1713 - Denon DCD1015 - Philips BDP3380/12 | Bowers & Wilkins VM1 - Boston Acoustics ASW250
Im still new to this I don't know stuff by numbers lol whats a PC8000 or PC8500
It deals with the speed that the ram is rated for. PC2 8000 runs DDR2 1000 and PC2 8500 runs DDR2 1066. PC2 6400 like you are looking at is rated to run DDR2 800. The PC2 part is actually stating the theoretical MB/s memory bandwidth of the module.
Asus Maximus Formula (Rampage Conversion Bios 0403)
Q6600 G0 stepping@4.05 Ghz
8GB G. Skill 1066 @ 1081 Mhz
EVGA 280 GTX
Auzentech Prelude
2X 74 GB WD Raptors in Raid 0 Windows 7 Ultimate 64
2X 1 TB WD Caviar Blacks in Raid 0 Vista Ultimate x64
Thermaltake Toughpower 1200W
DTek Fuzion V2 in a custom CPU only water loop
Coolermaster Stacker 830
Hanns-G 28" widescreen
Klipsh Pro-Media 2.1
G15 Keyboard and G9 Laser Mouse
Oh so its worth paying an extra 30 dollars?
Faster ram is always better. There will be headroom when you do overclock your quad.
For Q6600, a good kit of DDR2 is enough to achieve 3.6GHz running 1:1 memory, x9 multiplier, but you most likely need to spend more on a high quality heatsink to achieve that speed.
Since you are not overclokcing, I would choose your other components first and see if you have extra funds left for faster ram.
CPU: Intel Core 2 Quad Q9650 @ 4.05GHz / VID 1.15V / BIO 1.325V / Load 1.22V / LLC disable
HSF: TRUE Black + Scythe Ultra Kaze @ 1590rpm
MB: Asus Rampage Formula + Thermalright HR-05 SLI/IFX on NB + Enzotech CNB-S1L on SB / 450 x9 / 1:1 / BIO 0803
RAM: 8GB (4x2GB) OCZ DDR2 800 @ 900MHz / 5-5-5-18 / 2.2v / tRD 8
VGA: Evga 9800GX2 / 600 core / 1500 memory / 1000 shader
PSU: Corsair HX1000
HD: 4x Western Digital 1TB Black
-------------------------------------------- 3DMARK06: 21108 (result) | 3DMARK Vantage: P13541 (result) --------------------------------------------
So stick with the 66 dollar Corsair 4GB ram for now and then if I plan to overclock get the one you reccomended earlier in the future?
Also, I really like your motherboard whats a good motherboard that is kinda close to that one but alot cheaper lol , your MB is way outa my price range.
Get a fan controller instead if you plan on connecting all your 3pin fans to the motherboard. Different BIOs have different settings for fan speed. Asus's fan control settings is hit or miss. Performance, Optimal, Silent... not base on percentage nor voltage nor rpm...
Fan controller gives you more precise control and it's not that expensive.
PSU: Corsair HX1000
640GB WD
i like fan controller. i got a 6 knob zalman
getting cheap but silent 120mm/140mm fans would be preferrable also for 'quietness'.
g card fan could be the loudest fan depending on the settings, but as you running stock you probly wont hear that one either.
quaddie may come in useful...one day.
i go with cheapo ram and use dividers if i need to. (im on 5:6 for ages now)
...but there is nothing 'extreme' here
no OC means just get the cheap stuff and/or it comes down to personal choice.
i was looking for a hot pink coloured case, but there arent many options preferrably an expensive one with crap i dont need in it.
i7 3610QM 1.2-3.2GHz
I like mike's list, the things i would chose different would be PSU, memories and motherboard.
PSU: Silverstone strider 750w abot $110 on the egg
Motherboard: the asus P5Q Pro or the Biostar Tforce p45 HP, about $130 on the egg (two pci-e lanes, if you go latter for a second video card)
Memories: the mushkin ones, previously said on the thread.
Well and u can get a Rocketfish case for 60 at Bestbuy, and spare the 20 extra from the CM690.
I like that PSU alot, and the case forget that im getting antec for sure.
Still deciding on ram
Well you are the one that decide , rocketfish is alot better imo
PD: if you miss it, or havent seen yet here it is. the Rocketfish
It has all the Lian-li quality + all aluminum + very very big + lots of modding possibilities
For 60 bucks, thats a dream.
PD2: didnt read the page 2 from the thread , allready buy the antec 900, well it ill be for the next build
How about E7200 and HD4850 or 4870? I know there's also some G.Skill 2x2GB DDR2 1000 for $80 and DDR2 1066 for $85 (if you think the $5 and lighter-blue RAMsinks are worth it). P45 board such as a Biostar TPower T45 are supposed to be real nice. Corsair HX520, and I'd say look at XClio for their "Windtunnel" or "Windtunnel Advanced".
My toys:
Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
I've been talking with Alex and now i've decided on getting the RAM you guys have been reccomending me ( sorry I didnt see the rebate ).
Since you like Blue LED so much, here's my suggestion:
For mobo and video card, newegg is having a combo on asus p5q pro + asus hd4850.@ Newegg:
$210 - Intel Q6600
$87 - OCZ 4GB DDR2 1000
$130 - Asus P5Q Pro (-$20 promo code: EMCAHBAAB)
$150 - Thermaltake 700W modular
$85 - Seagate 500GB 32MB cache
$29 - Samsung SH-S203N DVD burner
$698 shipped (before $80 rebate)
@ Tigerdirect:
$210 - BFG 9800 GTX
$233 shipped (before $30 rebate)
@ Amazon:
$99 - Antec 900 (not my taste at all, it's your choice)
$42 - Asus Silent Square (personal recommendation only, for blue led love)
$141 shipped (no rebate)
Subtotal: $1072 shipped (before $110 rebate)
TOTAL: $962 shipped after rebate
For PSU, you can also go with Corsair 520W / 620W, whichever is cheaper for you. The reason I go with Thermaltake is because it comes with standard 8pin PCI-E connector cables, you have to call Corsair to get your cable. I might be wrong tho, they might be standard now. You don't have to worry about this even if you go with HD4850.
CPU cooler, other good options are Thermaltake V1, Zalaman CNPS9700LED, you probably won't like Xigametek's heatsink because of their white led with orange transparent fan. Anything around $25~50 that's not push-pin are recommended.
PSU: Corsair HX1000
These coolers are terrible for their price, the xigmatek one coolers alot better and its cheaper.
The corsair 650w is cheaper, more quiet than the 700W thermaltake... and possibly better quality.
Again, the new 320gb or 640w HDD's are very quiet and perform well.
stock 800Mhz ram would get you 3.6ghz (400FSB), so no point in getting something better, unless the price diff is small.
the Biostar p45 board is an monster indeed, overclocks FSB like crazy. Good option if its not much more than p35 mobos.
Haha yeah Source, again im not familiar with any names, which brands are good, which brands are bad ( thats the whole point in starting this thread I needed help with everything ), I just dont want to under do it and then having to buy another PSU in a short time thats why im trying to go for the higher Watt.
Alex's list is basically everything I want..
If you had read the previous page, you read that more than 4 people in a row are voting for the Corsair.
Not that the Higher Watt-PSU's from Thermaltake are that bad. But would rather buy a Corsair over Thermaltake.
Yup, cheaper, quieter, reliable, great support and warranty, more efficient and impressive output quality. Its not by accident that everyone is getting them lately.
Yeah trust me i've read every page throughly I dont see how a lower wat PSU even though its made from better parts and stuff can be better than a higher watt though..
Then go with the Thermaltake.
Yeah, if you don't want to go with what other say, grab a very high Wattage PSU...
FYI, the Corsair HX620 blows out 600Watt on the 12V line and 170Watt on the 3V/5V line
http://corsair.com/products/hx.aspx
You win, here you go:
http://www.newegg.com/Product/Produc...82E16817182096
EVGA 280 GTX
Auzentech Prelude
