Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: aegis panel suggestions ;)
    Nov 2006
    Poland / Rypin
    all right
    What is my suggestion ?
    - regulation of multi
    - manual regulation of fans, specially cpu.
    - it's hard to say but i try. It's about the increase the htt. Sometimes it's like that:
    Mine settings AEGIS Panel settings :
    for example:
    220 220
    225 223
    230 : 230
    245 : 243
    250 : 247
    it's very frustrating because I can't find max stable htt
    from me this suggestions, what yours ?
    Schedule of Live Extreme Overclocking - info Thread
    Quote Originally Posted by K404 View Post
    "My Backup is bigger than Your Backup"
    Xtreme X.I.P.
    Nov 2002
    Shipai
    congrats on the first thread in the suggestion box section
    1. should be doable
    2. not sure, but might be possible
    3. not sure what you mean...
    you mean that 250 doesnt set 250, but 248 for example?
    well the reason for that is that there arent 1mhz steps afaik, so if the option would be called like what setting really exists, the fsb list would look like this:
    420
    421
    423
    424
    426
    427
    428
    430
    which looks odd and people might complain where the other settings are and why they dont show up...
    but if you want i can check if the options can be renamed to show exactly what the speed should be
    it might also be that depending on what memory divider you use or depending on how the pll locks the fsb varies slightly.
    so when you set 430 once it might be 428, the next time 428, the next time 430, the next time 431
    see what i mean?
    ill check with the engineers and will get back to you
    Nov 2006
    Poland / Rypin
    I understand saaya
    big thx.
    but when my dfi infinity ultra m2 was in action I have used clockgen and he increase htt in 1mhz steps. svende (my team mate) and I were benching on abit kn9 and the 3600+ (brisbane) 1 mhz increase was ok too
    but even without this 1mhz steps I can make some scores
    Xtreme X.I.P.
    Nov 2002
    Shipai
    hmmmm
    the pll supports fine adjustment steps of below 1mhz afaik, so once in windows you should be able to reach any fsb sped you want, even x.5mhz maybe we can implement fine adjustments like setfsb has... ill ask the engineer on monday
    Nov 2006
    Poland / Rypin
    htt saaya
    Xtreme X.I.P.
    Nov 2002
    Shipai
    :PPPPP yes HTT
    Jul 2007
    ARIZONA
    great thread soooooo... eye would like to see the right panel (volt panel) reflect whats in the bios like say ...
    cpu v
    dram v
    nb v
    fsb v
    vtt v
    sb/pll v
    +12 v read=
    +5 v read=
    +3.3 v read=
    and in the center panel for the multi to be recongized correctly
    [SIGPIC][/SIGPIC]
    PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
    FOXCONN MARS
    COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
    BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
    OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
    Quattro 1000W
    Radeon 2-4850's in crossfire
    OCZ Vertex SSD thanks Tony!
    ALL PIPED INTO HOUSE AIRCOND ;}
    *QUANTUM FORCE* saaya & sham rocks !
    *REAL TEMP*
    At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
    *MEMSET* Felix rocks !
    *SUPER TEC MAN* UncleJimbo rocks !
    OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
    Xtreme X.I.P.
    Nov 2002
    Shipai
    ok, just told the api guy, should be possible, and yes, the panel should be fixed soon, we are working on a new improved panel that should work more reliable and need less reworking
    Nov 2006
    Poland / Rypin
    nice to hear that saaya
    Xtreme X.I.P.
    Nov 2002
    Shipai
    heres feedback from the engineer regarding aegis panel readings on MARS:
    cpu v should be OK
    dram v should be OK
    nb v should be OK
    fsb v (=VTT)
    vtt v not sure
    sb/pll v unfortunately NO afaik
    +12 v read= should be OK
    +5 v read= should be OK
    +3.3 v read= should be OK
    he said he can probably start working on this next week
    Jul 2007
    ARIZONA
    sounds great to me ! you guys rock !!
    [SIGPIC][/SIGPIC]
    FOXCONN MARS
    Quattro 1000W
    *REAL TEMP*
    Jun 2008
    Quote Originally Posted by saaya View Post
    cpu v should be OK
    dram v should be OK
    nb v should be OK
    fsb v (=VTT)
    vtt v not sure
    I'm getting excited about this!
    Hmmmm, can i request a Quantum Force wallpaper?
    Mobo: Foxconn MARS
    Cpu: Wolfdale E8200 C0 @ 4ghz @1.38v w/ TRUE-120 Black
    GFX: 8800GT G92 @stock
    Memory: Team Extreem 2x1 5-5-5-15 1100ghz @2.11v
    Hard Drive: SB 500GB
    Optical Drive: LG 22x DVD/RW LS
    Case: Lian-Li PC-G7B
    Foxconn ROCKS!
    Nov 2006
    Poland / Rypin
    grungero, register at the quantum force webstie
    there is a lot of stuff about mars, blackops, programs
    Jul 2008
    how bout memory timing function setting like memset?.. can implement into aegis panel?... also profile settings... for example ... u underclock ur pc when u leave it on for file download or whatever... and overclocks it for gaming and stuff... it would be great if you can store those settings in aegis panel and swap between profiles whenever needed...
    CPU: Intel C2Q Q9450@3.0Ghz WaterCooled
    MB: Foxconn Mars with P12 Bios
    RAM: 2GB Crucial Ballistix Tracer 6400 @ 905Mhz (5-5-5-15)
    GPU: MSI NX8800GT 512MB with AC Accelero S1 Rev. 2[745/1862/2000]
    HDD: 320GB+250GB WD +320GB Seagate Barracuda Hard Disks
    PSU: Acbel R8 700W
    CS: Lian Li V2000B with Transparent side panel
    [WC Spec: Thermochill PA120.3, Swiftech MCRES Micro Reservoir, D-Tek Fuzion v2 with Quad Core Midplate, Nirox P2800 Pump]
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Quote Originally Posted by IcEMoCHa View Post
    memset functionality, maybe... but i like memset and felix88 is doing a great job with it
    i prefer supporting him than offering a competing tool for our boards
    profile saving and apllying is possible with the p45 boards and later with the push of a single button
    not sure if we can add that for mars and blackops :/
    Jul 2008
    profile saving and applying shud be possible since we can change the core clock on the fly... just save the settings and switch between them whenever needed...
    PSU: Acbel R8 700W
    Xtreme X.I.P.
    Nov 2002
    Shipai
    i know, thats what i thought as well but our application guy says its not that easy
    maybe its a misunderstanding... the guys here dont speak english so well and my chinese is... not that great either :P
    ill check again
  18. #18
    Xtreme X.I.P.
    Nov 2002
    Shipai
    heres an updated version of aegis panel for MARS:
    http://www.xtremesystems.org/forums/....php?p=3157495
    fatalbert, i asked the application engineer to work on the destroyer now
    - regulation of multi should work
    - manual regulation of fans, specially cpu. should work
    cant be changed, the pll is inside nvidias chipset, and they only provide those fsb steps...
    so we cant offer smaller steps...
  19. #19
    Nov 2006
    Poland / Rypin
    1. nice
    2. nice
    3. fine, I can live with it. no problem if this can't be work so ok
    so when a version "destroyer friendly" will available ?
    thx sayaa
  20. #20
    Xtreme X.I.P.
    Nov 2002
    Shipai
    to change the fanspeed you only need to click on the fan symbol, and you get a couple of options on how you want the fan speed to be regulated, so you tried this but it doesnt work on aegis panel with the destroyer? Did you try the latest version of aegis panel?
    about cpu multiplier settings, our api guy says its a lot of work and he doesnt have all the informations from amd/nvidia to do it, so he would have to do a lot of trial and error work :/ Does Crystal CPUID work? does overdrive work on the nvidia chipset? it might allow some cpu functions like multiplier adjustments?
  21. #21
    Nov 2006
    Poland / Rypin
    fan speed change doesn't work, I don't know how a should do to change speed, I tried a lot of times and speed was the same I'm using 1.0.2.31 version.
    about cpu
    oh, without this I can life too, but I want to have a lot of function in one program. crystal it's work but mutlies too, but I prefer other programs Aegis panel Roxxx
    amd overdrive doesn't work on nforce.
  22. #22
    Xtreme X.I.P.
    Nov 2002
    Shipai
    well you click on the fan symbol, then you get a pop up with a drop down menu to select if you want this fan to spin at full speed, be controlled by cpu load, or by temperature etc. so what happens when you change those settings? the fanspeed is always the same? For all the fans?
    Overdrive doesnt work on nvidia chipsets hmmm that sucks... at least the cpu features should be available, but i guess the chipset guys at amd and nvidia dont like each other
    good to hear that crystalcpuid works!
    and yes, we will try to implement more features into aegis panel, maybe it will become something like amd overdrive with mem timings and a stress test, but thats a long road to go on, we only have one single application engineer and hes working on several projects...
  23. #23
    Nov 2006
    Poland / Rypin
    well you click on the fan symbol, then you get a pop up with a drop down menu to select if you want this fan to spin at full speed, be controlled by cpu load, or by temperature etc. so what happens when you change those settings? the fanspeed is always the same? For all the fans?(...)
    always the same fans speed.
    Overdrive doesnt work on nvidia chipsets hmmm that sucks... at least the cpu features should be available, but i guess the chipset guys at amd and nvidia dont like each other (...)
    it's not our problem
    we have got Aegis panel
    ohh
    if aegis panel will have that features it will be very very good application
  24. #24
    Xtreme X.I.P.
    Nov 2002
    Shipai
    alwyas same fanspeed... hmmmmm could it be that its the same fanspeed cause the cpu is so hot that by temp regulation its running full speed, when you set it manually to max it will also be full speed?
  25. #25
    Nov 2006
    Poland / Rypin
    cpu is a64 1620, one core and no full speed but 10x200. it's cold
    cpu fans has got full speed always.
