Hi there ;
Today i got my ls working again .This is the denfoos 5.5 clx with R404A .
using E8500 @ 5000 mhz and 1.504 v (cpuz) Idle temp are -30 c speed fan or 227 c asus prob .
load temp under prime are 20 C according to both software
I have checked for bad contact 3 time the evaporator make a damn good contact with the cpu . i am using artic ceramic as thermal paste what is wrong ??.
Condenser temp is 47-50c , the compressor is also pretty hot . i have not checked the evaporator temp since i am using the vapochill without the card (it is broken).
Something wrong or the ls is damn poor
note the ls is stock and not modded . the cpu put around 160w in this configuration.
