what dose E-sata use (sata1)1.5gbs or (sata2)3.0gbs ?
usb 3.0 is suppose to be 4.8gbs vs 480mbs usb from 2.0
how ever if e-SATA is using Sata it can get to 6gbs & I'm sure we'll see more devices use e-sata over the coming years.
Why, did Sata II already come out?
Sata 3Gbps != Sata II. Common misconception.
http://www.serialata.org/namingguidelines.asp
It'd be an alternative if it was widely available.
As of now, it only comes on a few external drives and camcorders;
but I haven't seen many pendrives or others with fw; and those
devices that have fw are a very small percentage in the market and
cost a significant amount more.
No, networking devices have a MAC address and MAC layer.
I'm sure you have seen it, an IP address is 123.456.789.123
for example and can be dynamic; a MAC address is eg.
12:3a:bf:19:5c:67, and is static and can identify a machine.
Usual suspects: i5-750 & H212+ | Biostar T5XE CFX-SLI | 4GB RAndoM | 4850 + AC S1 + 120@5V + modded stock for VRAM/VRM | Seasonic S12-600 | 7200.12 | P180 | U2311H & S2253BW | MX518
mITX media & to-be-server machine: A330ION | Seasonic SFX | WD600BEVS boot & WD15EARS data
Laptops: Lifebook T4215 tablet, Vaio TX3XP
Bike: ZX6R
Well, you can change a MAC address, but it's still a lot more static than an IP address. The wireless network on the university where I study uses the MAC address of my laptop to verify whom I am, along with account and password and stuff. But I will have to register the MAC address of my mobile phone's WiFi to be able to use the wireless network on my university for example, otherwise they won't allow me to connect wirelessly. It's more of a security feature in this case as I can only use certain features when I'm on the university's network and they don't want someone to just hop on to the network and start using it as well. (I use VPN at home to do the same)
"When in doubt, C-4!" -- Jamie Hyneman
Silverstone TJ-09 Case | Seasonic X-750 PSU | Intel Core i5 750 CPU | ASUS P7P55D PRO Mobo | OCZ 4GB DDR3 RAM | ATI Radeon 5850 GPU | Intel X-25M 80GB SSD | WD 2TB HDD | Windows 7 x64 | NEC EA23WMi 23" Monitor |Auzentech X-Fi Forte Soundcard | Creative T3 2.1 Speakers | AudioTechnica AD900 Headphone |
eSATA currently uses SATA 3,0 GB/s and maximum cable length through a native eSATA port is 2 m. while a 'passive' port is reduced to 1 m. because it lack the signaling needed to support longer cables. When a mobo has a build in eSATA connector found at the rear port cluster, then it will be of the full eSATA port.
Wow, SB8xx are going to be a kickass SB's. AMD are improving everything they can while fighting on every front. That SB should add a great value to the upcoming Deneb based platforms. Deneb loks like it is going to be more competitive to Yorkfield then Phenom was to Kentsfield. It seems they have fixed the Spider. In such case the Spider2 with an Radeon 48xx will offer a great performance and will have a very high overall value for the price it has. Bravo AMD!
Thx for the explanation
No, were you... positive
Anyhow, if it's going to compete against Yorkfield majorly depends how Deneb is going to do in the end; most important thing I think is to improve Vcore/clock scaling. But as long as they rule out most things which might be a drawback it's only better. Got to start somewhere at some point and fix/improve things step by step and everytime you did one piece you've one thing less to worry about... at least, that's how I think when i got to tidy my room
But Im dieing to see RD890 features though. I hope metro posts them tomorrow... (which is only in one hour).
Synaptic Overflow
CPU:
-Intel Core i7 920 3841A522
--CPU: 4200Mhz| Vcore: +120mV| Uncore: 3200Mhz| VTT: +100mV| Turbo: On| HT: Off
---CPU block: EK Supreme Acetal| Radiator: TCF X-Changer 480mm
Motherboard:
-Foxconn Bloodrage P06
--Blck: 200Mhz| QPI: 3600Mhz
Graphics:
-Sapphire Radeon HD 4870X2
--GPU: 750Mhz| GDDR: 900Mhz
RAM:
-3x 2GB Mushkin XP3-12800
--Mhz: 800Mhz| Vdimm: 1.65V| Timings: 7-8-7-20-1T
Storage:
-3Ware 9650SE-2LP RAID controller
--2x Western Digital 74GB Raptor RAID 0
PSU:
-Enermax Revolution 85+ 1250W
OS:
-Windows Vista Business x64
ORDERED: Sapphire HD 5970 OC
LOOKING FOR: 2x G.Skill Falcon II 128GB SSD, Windows 7
