Main rig:
CPU: I7 920C0 @ 3.6Ghz (180*20)
Mobo: DFI UT X58 T3eH8
RAM: 12GB OCZ DDR3-1600 Platinum
GPU/LCD: GeForce GTX280 + GeForce 8600GTS (Quad LCDs)
Intel X25-M G2 80GB, 12TB storage
PSU/Case: Corsair AX850, Silverstone TJ07
Yea the lead solder is bad news bears but it's the only stuff that doesn't seem to crack with lots of heat over tie. I have heard most of the xbox 360s problems all go back to the BGA Grid under the GPU toasting itself then melting an cracking. (X-clamp fix for the win.)
actually... i cant remember if it was that, or.. the flux which I had put into the holes prior to soldering - I had grabbed a syringe with a nice fine needle, filled it with flux & then squeezed it into the holes. My soldering 'philosophy' is: 'where there is flux, there is solder'
& as a small update: I've finished fulltime studies for the yr, & I've just started work last monday.. = $$$
so heres to hoping I earn enough between now & Christmas
DNA = Design Not Accident
DNA = Darwin Not Accurate
heatware / ebay
HARDWARE I only own Xeons, Extreme Editions & Lian Li's
https://prism-break.org/
well I got a surprise today - my RMA RAM came waaaay earlier! I was told ETA would be approx. end of Jan.
anyway, so I went straight to testing...
I'm in the middle of trouble-shooting.. but.. atm it looks like:
FAIL
I'm getting the same combo of diagnostic LEDs as before
only other possibilities are:
- i'm doing something wrong
- the mobo was rooted before I even started
its quite likely I'll be buying another mobo & this time test if it works first
if anyone wants to try & help:
i cannot for the life of me figure out the diagnostic code:
http://cid-ddcb6706c2587cbb.skydrive...0pg131-143.pdf
here is the mobo manual
if u go to page 131 of the manual (adobe pages says 143) there it talks about the error codes & the LEDs.. if anyone knows how to decypher the lingo lemme know, I can post a pic of the LEDs as there is a combo that stays light after power-up
I've essentially finished trouble shooting - if u want to read on what went down:
http://www.xtremesystems.org/forums/...d.php?t=200843
post #676 onwards
