Results 1 to 14 of 14
Thread: thermal controled fans HELP!
    Jul 2007
    ARIZONA
    got 2 of these fans spec's say thay will do 5000+ rpm and put out 121 cfm want to put them on my new COOLIT unit
    but thier a green thermal do daaa that controls the speed acording to temps ... want to by pass that and run them at full speed ! could you just wire across the leads for the thermal control (green thing ) and remove it (green thing) ???
    dont care about the noise played with jets & hoggs all my life & half def anyways
    any help would be greatfull .. here's a link to the fans
    http://www.directron.com/ds923812hbtl.html
    again thanks in advance
    [SIGPIC][/SIGPIC]
    PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
    FOXCONN MARS
    COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
    BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
    OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
    Quattro 1000W
    Radeon 2-4850's in crossfire
    OCZ Vertex SSD thanks Tony!
    ALL PIPED INTO HOUSE AIRCOND ;}
    *QUANTUM FORCE* saaya & sham rocks !
    *REAL TEMP*
    At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
    *MEMSET* Felix rocks !
    *SUPER TEC MAN* UncleJimbo rocks !
    OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
    Xtreme Cruncher
    Oct 2005
    BFE
    I could be wroing but your fans are not what is dealing with the heat it would be your mobo. if you take the black wire (ground) and the red wire (12v) and plug them into the psu then you should be running at 100%. you can try this by using a small wire and plugging into the 3 pin clip and the psu molex connector. red to yellow and black to black.
    Jul 2007
    ARIZONA
    ya thought about doing that
    thay came off of a pair of dell's with plain alum sink with a 90* duct to the rear of the box with this fan mounted at the back
    that green thing (in the middle of the hub) is a thermal sensor
    [SIGPIC][/SIGPIC]
    FOXCONN MARS
    Quattro 1000W
    *REAL TEMP*
    Xtreme Cruncher
    Oct 2005
    BFE
    yeah I have seen several fans with the thermal sensors! I remember reading that you can cut them out and jump it but I don't know if that is true or not.
    Jul 2007
    ARIZONA
    thanks you littleowl thought eye read that somewhere also so thats 2 feel better now !!
    hopeing uncle jimbo will show up the man seems to know his biz
    [SIGPIC][/SIGPIC]
    FOXCONN MARS
    Quattro 1000W
    *REAL TEMP*
    Mar 2008
    Houston TX
    Quote Originally Posted by littleowl View Post
    To make the fan run full speed, take the thermistor out and replace it with a resistor which has a larger value. You can just measure the resistance of the thermistor with a voltmeter. It is probably a 10K at 25C unit, so a 15K resistor should give full speed.
    Feb 2008
    I thought some thermally controlled fans would just run at 100% if the two probe leads were shorted?
    Jul 2007
    ARIZONA
    thank you uncle jimbo !
    figgered a resistor might be required just didnt have a clue which ones
    will mesure it and get the required value resistor
    thanks again all for your replys!!
    [SIGPIC][/SIGPIC]
    FOXCONN MARS
    Quattro 1000W
    *REAL TEMP*
    Xtreme Cruncher
    Oct 2005
    BFE
    Quote Originally Posted by Uncle Jimbo View Post
    hum I learn something new everyday on this forum!!!
    Mar 2008
    Houston TX
    Quote Originally Posted by ZOMGVTEK View Post
    No that will turn the fan off - see above. You need a resistor between the leads.
    Apr 2008
    Sanyo Denki fans seem to work differently. Adding resistance raises the
    temperature set points. To run an external thermistor controlled fan at
    low speed all the time, you replace the thermistor with a 10k resistor.
    To run the fan at high speed all the time, connect the control lead to the
    negative lead.
    http://www.sanyo-denki.com/CurrentCo...alog/Index.pdf
    (thermal speed controlled fans)
    Mar 2008
    Houston TX
    Quote Originally Posted by leuler View Post
    negative lead.
    Thanks - good info!
    Replacing the thermistor with a 15K variable pot (or 1.5 times whatever resistance the thermistor measures at 25C) allows you to adjust speed in either type of fan
    Apr 2008
    Thanks - good info!
    Even better info!
    Jul 2007
    ARIZONA
    thank you thank you exellent info !
    yup learn something new every day
    [SIGPIC][/SIGPIC]
    FOXCONN MARS
    Quattro 1000W
    *REAL TEMP*
