+ Reply to Thread
Results 1 to 13 of 13
Thread: xp1700+ @ 2.5ghz air
    Sep 2003
    DE
    0
    What do you guys think?
    8rda+ Rev 1.1 A1
    AXDA1700DLT3C JIUHB 0319WPMW
    2x512mb twinmos ch-5 dc sync
    This is on a crappy Vantec AeroFlow....
    If only I had better cooling, I would be willing to risk more.
    For the limited testing done, it's stable so far.
    Feb 2003
    0
    Its nice at that vcore - your temps look pretty good too..
    good clock there matey
    Da[]San
    3dmark 2001 21519
    Xtreme Relic TheDude's Avatar
    Jun 2002
    Hilton Head, S.C.
    0
    Sweet!
    I'm playing with a new 1700 also...crappy air cooling. Here's where I am so far.
    I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me.
    Hunter S. Thompson (1939 - 2005)
    Jun 2003
    Ohio
    0
    thedude, that really isn't very good for a 1700+.......Mine can hit 2200mhz at 1.6Vcore.
    Jun 2002
    Hilton Head, S.C.
    0
    I got all the way to 180fsb at 1.5 vcore and then it started demanding volts. I think it's my crappy cooling...an old SK7. I will see what it does in a 404 prommie soon.
    Xtreme Addict kup's Avatar
    Jan 2003
    Canterbury, UK
    2
    Now that's the spirit!
    Those week19 1700+'s are demons, mine is now Prime+3d+Audio 24/7 @ 2.8GHz with only 1.8v in my Stock Prommie!
    Used to need 1.83-5v!
    | Asus nVidia 580 GTX @ 850MHz |
    | Windows 7 x64 Ultimate | Mac OS X 10.6.8 | Mac OS X 10.7.2 |
    | Intel Core i7 970 @ 4.2GHz | Gigabyte X58A-UD9 | 12GB Corsair 2000MHz 8-8-8-24 |
    | HTC HD2 | MIUI 1.10.21 | Android 2.3.7 | TyTung 12.4 Kernel |
    New Builds Coming Soon..
    Xtreme Member speedstream5621's Avatar
    Sep 2003
    Lake Oswego, Oregon
    0
    The SK-7 still gets the job done, provided you have a good fan on it.
    With ambients of 69F and 1.7v of vcore, my CPU temp is 34C. I only have a 3200RPM fan too.
    Case cooling also makes a large difference too.
    Samsung SyncMaster 710N
    Thermaltake Purepower 420w
    Athlon 64 3000+ 939 @ 2.42GHz (242x10)(1.55v)
    Gigabyte K8NS Ultra-939
    2x512MB Kingston Value PC3200 (2.5-3-3-10-1T)(2.7v)
    Visiontek X800 XT
    Heatware
    Xtreme Member x2sandman's Avatar
    Dec 2002
    0
    that chip that the dude has was my old chip that i got to 2.65ghz on air, so we're both hoping for 3ghz on the prommy
    Xtreme Member TheDogFather's Avatar
    Jun 2003
    Poole UK.
    0
    Nice work Mrk200
    Ive got the exact same chip, just hope it does the same.
    TDF.
    Xtreme Member Spec3's Avatar
    Jan 2003
    Tallinn, Estonia
    0
    Nice chip man. My 0308 did 2614Mhz on just air too. It's to bad I cracked the core with my waterblock
    Xtreme X.I.P.
    Nov 2002
    Shipai
    1
    nice! now mod your psu to get better rails and aim for 240dc or higher. upping the rails gave me 20fsb+
    Jun 2002
    North of Toronto
    0
    Re: xp1700+ @ 2.5ghz air
    same stepping as mine... same results...
    I have an old KT333 mobo and pc2700 so I ain't gonna get the memory bandwidth you are...
    Last night I went to 14x180... more testing to come.
    my 0319 acutally posts at 2745 on air!
    8rda+ Rev 1.1 A1
    AMD & ATI Powered!
    DFI Lanparty S939 NF3 Ultra-D | AMD X2 4200 @ 2.6GHz | 1gb OCZ pc3200 rev2 TCC5 | ATI X800XT Platinum Edition| 2x120G WD | Plextor 712a | Antec SLK3700AMB| 520w OCZ PowerStream | Zalman 7000Cu
    My Heatware 100% Positive
    Sep 2003
    DE
    0
    I took my Antec sl350 apart, and there aren't any pots. Also there isn't a brown wire by the +3.3v orange lines. So I'm going to have to wait until I get home (at college now), and swap with my 400w antec psu.
    Besides, my ram doesn't seem to want to go much higher than 218 stable. So not sure if improving the rails will benefit me at all.
+ Reply to Thread
