Hi!
I bought Foxconn Black Ops a couple of weeks ago and i have been really happy with the board, but then yesterday it started to acting strange. When booting i get an error code 54 and constant beeping, the card locks and i have to power down before the board can boot again. But if i go into BIOS and save then the same problem appears.
If i clear Cmos, and change the settings then i can boot, power off, start up the board a couple of times before this happens again.
I have tried evry BIOS availible but the same problem appears after a couple of reboots. Also i dosnt matter what settings i use, this start to happening after a couple of boots regardless of what i have done. I have also read the debug thread and the "save and exit CMOS - Power off PSU" only helps for the moment, after a couple of boots the the board get locked in the error 54 again.
Before this i have achived really great results with the Black Ops board and like i said, i been very happy with it, but now i am just getting frustrated because nothing i have tried helps. So now i decided to ask if someone here have a qlue on what to do, i just cant get it to work like it use to.
Also i have tried other memorys etc but that doesnt help either.
So if someone had the same problem and fixed it the please i would be gratefull if you could help me, or just give me some pointers because i am running out of ideas. It feels like i have tried evrything but nothing so far has helped, the board locks after a couple of reboots.
EDIT: Even with 24/7 stable settings this happens, between lock down i can go into windows, and i have tested the stability so that shouldnt be the problem.
Also, this morning i changed to BIOS G27 and discoverd thath if i go into integrated Pheripherals / USB Device settings the board locks. This is just a problem i had with G27 BIOS. But beside this problem i think that BIOS G27 is great, especially memory stability is much better with this version, or atleast it have been so for me.
Thanks in advance
The system used is.
Intel QX9650 Extreme
Foxconn Black Ops X48 ( right now on BIOS G27)
Super Talent ProjectX 1800 7-7-7-21
Asus 9800GX2
Silverstone Olympia 1000W
Right now the system is cooled with air.
