Hi Iany.
So far for pumps I was thinking about 2 MCP355 from frozencpu, one with the xspc reservoir on top and one just regular
Is that good enough for the whole setup? The 2 mcp355s?
I will get a 120.2 and a 120.3 Ian.
Just making sure the 2 pumps are enough to drive my loops now. The GPU loop should get enough pressure from the CPU loop shouldn't it? Since the priority here is making sure our cpu has the best cooling?
Also for barbs am I buying the right ones for my setup?
They're the :
Thermochill 1/2IN Chrome Plated Barb Fitting G3/8 Threads *Single Barb*
" G3/8" BSP 1/2" Fitting
3/8" BSP Threaded barb without rubber O-Ring - PTFE Tape required to seal. 2x fittings required per radiator. "
