Hi guys, I'm a newb to watercooling.
I've done some reading now and I'm really torn between the PA120.3 and PA160.1 reservoirs. Can you guys outline specific instances in which would be best?
My parts that needs cooling will be:
Striker II Extreme
Qx9650
2 GTX 280 SLI
Now I know that the reservoir is one thing, another is loops, pumps and overall size. I really don't care how big the stuff is as long as it fits in my V2110B, but I'm really worried that my 280 SLI loop will DESTROY my temps. I'm wondering how many loops you guys recommend and which reservoirs I'd use to cool between the loops. I'm assuming since the GTX280s have very high TDW that i'd need a much bigger one than the CPU and MOTHERBOARD but I'd like to build a lasting setup
Any suggestions would be great guys.
Thx
