Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Lian Li PC-A77 mod: Project[Thessa]
    Mar 2008
    Philippines
    Ok..A little introduction if i may..Basically, the goal is to watercool the case all internal without ruining the case's simple and minimalistic design. Yet maintaining a cool and quite system. The system will be overclocked to its highest stable clock(3.4ghz) on stock vcore.
    So i present Project[Thessa] < named after my significant other as a tribute for financing this whole project. LOLZ! ;-D
    All Mods are done by tantric @http://www.tantricmodz.com
    Probably the No. 1, if not the best modder in the Philippines!
    Loop 1: Ek Res 250> MCP655>TC PA120.3> Q6600> NB> SB (EVGA 680i)
    Loop 2: Ek Res 150> MCP655> BIX II 240 > 2 x EVGA 8800gts 512mb (Will Be changed later to BIX II 360)
    Pics!
    Top Mounted PA120.3
    Lasercut Acrylic PA radgrill
    Powdercoat done..mounted the res and top rad
    front rad mounted in custom hd cage bracket
    window cut
    misc mods
    thats it for now..some minor adjustments will be done later..
    the parts i will be using
    tubes will be replaced to a tygon 3400 1/2id 3/4od on compression fittings on the cpu block. the rest of the fitting will be the dangerden fatboyz
    I am Xtreme
    Jul 2007
    The Sacred birth place of Watercooling
    nice.
    Quote Originally Posted by skinnee View Post
    No, I think he had a date tonight...
    He and his EK Supreme are out for a night on the town!
    Jan 2008
    Sweden
    Ah i neeed a bigger case my lian-li pc7 isnt big enough, although that is a damn nice !
    24/7 Setup: Asus maximus x38 / E8500 E0 (500x8) Dtek Fuzion / Ballistix old rev 4-4-4-4 @ 1000MHz / 2900XT Ek fullcover cf / Silverstone TJ-07
    Bench: Commando / Tpower i45 / P5K / E8500 E0 @ http://valid.x86-secret.com/show_oc.php?id=433935 / modded mach2 r507 / Old rev ballistix /
    Apr 2008
    I like the case cutout for the radiator, looks very professional.
    iRAQ - Apple's upcoming server racks
    May 2008
    VA
    good looking mods. I like the pump emerging out of the bottom plate.
    not crazy about the mirror... to me, it doesnt fit w/ all the flat black.
    Apr 2008
    i didn't even notice the mirror...i like it.
    Banned
    May 2008
    vermont, yes i like women
    nice man that case looks sick! I wish I could have mine done professionally!
    Aug 2007
    Brasilia - DF - Brazil
    I'll modify the mobo tray in my G70 next week. I'll use most of your ideas, great job.
    My Lian Li G70
    Asus P6X58D-E * i7-930 * Saphire 7970 * 6GB Corsair XMS3 1600 C7 * Crucial M4 256GB SSD * Lian Li G70W Powdercoated
    Watercooled by single loop Coolgate Quad 120 + Swiftech MCR220 with San Aces H1011 * EK Supreme HF * Koolance VID-AR797 * EK Asus X58 full set * DDC 3.25 with EK Dual Top/Res
    Royal Administrator
    Jul 2005
    New York City
    Looking great.
    I suggest you to flip these fans.
    Apr 2008
    awesome work mate
    Xtreme Cruncher
    Jul 2007
    @ the computer
    wow 2 internal loops is crazy. makes it look very clean
    [SIGPIC][/SIGPIC]
    Feb 2008
    Mirror? Where? Down the side of the bays? I think that's just a piece of black acrylic to cover the metal up.
    Aug 2007
    Did you take the case apart for painting?
    What tool did you use for the round holes on the mobo tray? A hole saw? Did you cut the holes without a wood support on the back of the tray?
    My Lian Li G70
    Xtreme Cruncher
    Oct 2007
    Netherlands
    Impressive! Subscribed.
    Quote Originally Posted by CyberDruid View Post
    I am thinking "Bacon Railgun" might be the ultimate weapon, as shooting puppies out of a cannon seems inhumane...
    [ build in progress ]
    Q9450, P5Q-Pro, 4Gb TeamXtreem Dark + 4gb Buffalo Firestix 1066, Silverstone DA650, Silverstone TJ09, 2×WD6400AAKS Raid0, 2× Sapphire HD4870, Dell 2407WFP-HC.
    Liquid:
    loop1: EK Supreme, MCW30, PA120.2, DDC3.2+XSPC top
    loop2: 2×MCW60, D5 vario, MCR320
    Mar 2008
    Philippines
    Quote Originally Posted by lyl View Post
    its just a black opaque acrylic just to cover the front bay cages..i can always paint it flat black to match the matte black powdercoat.
    Mar 2008
    Philippines
    Quote Originally Posted by leo_bsb View Post
    yes it was taken apart for powdercoating. the holes on the mobo is already there when you buy the case except for the long hole near to ek 250 res and the buttom 2 circle holes. used a hole saw for that one.
    Sep 2007
    NYC
    wow.. that looks awesome. im actually doing my pca77 build currently too but obviously its no where near as good as this.
    PRIMARY
    2600k | ASUS MIVE B3 | 4x4GB GSkill Ripjaws DDR3 1600MHz | Ultra X3 1600W | GTX 580 3GB TRI SLI | OCZ Vertex 3 240GB | Dell U3011 Surround | Win 7 x64 | Thermaltake Level 10 GT
    STORAGE
    Q8200 | MSI P7NGM | 2x2GB GSkill DDR2 800MHz | Rosewill RD400-2-SB 400W | 4x WD Caviar Black 1TB (RAID 5) | Ubuntu 11.04 | Antec Mini P180
  18. #18
    Mar 2008
    Philippines
    just a trial run of the tubes. it may be revised when better layout arises etc...final tubes will be a black 3400 3/4od tygon
    comments/suggestions are very much welcomed
  19. #19
    Jul 2007
    Montreal, Canada
    cant see that second pump clearly, but is it pumping into the res?
    MM Ascension Duality - Sky White
    i7 920
    Gigabyte EX58-UD5
    Gigabyte 4870X2 , DD 4870X2 Waterblock
    3 x 2GB Patriot Extreme Viper
    Silverstone Decathlon 1200W
    Raptor X 150, WD Black 1TB
    4 x Samsung F1 1TB
    3 x 320 Seagate 7200.10
    X-Fi XtremeMusic
    Stinger all copper V8 1366 (Soon to come)
    Thermochill PA.120.3
    Swiftech 655 Vario pump
    Maze 4 NB block
    EK Multi option res 250
  20. #20
    Mar 2008
    Philippines
    Quote Originally Posted by Apollo4g View Post
    no..that is the inlet of the pump. ;-)
  21. #21
    Jun 2008
    the tubing going to the 2nd res (small one) is to long maybe you should remount your res somewhere else to make the tubing shorter
  22. #22
    Sep 2007
    NYC
    ive got a quick question. how come you're not putting the triple rad in the loop with the 2 vid cards and the double on the cpu loop? wouldnt 2 8800gts cards put out more heat then a cpu,nb,sb? i guess it depends on when you're swapping it out for a bix 360.
    PRIMARY
    STORAGE
  23. #23
    Mar 2008
    Philippines
    its "not" that hot of a card. ;-) we pre tested the rad with the cards and it idle at 27-29c according to everest and gpu-z. thats with YL Highs..
  24. #24
    Mar 2008
    Netherlands
    i like the routingof the tubing. Only the res to pump tubing should be shortened as mentioned above
    Intel Q6600 @ 3.6GHz
    Asus Blitz Formula SE
    OCZ ReaperX PC6400 2x2GB
    Sapphire HD4870x2
    X-Fi Elite Pro 7.1 & Logitech Z5500
    Samsung Spinpoint T166 500GB
    Samsung 226BW
    Zalman ZM1000-HP
    Watercooling
    Loop 1: DDC3.2 (XSPC Restop), Fuzion v2, BIGTX360 (6x S-Flex F)
    Loop 2: DDC3.2 (XSPC Restop), EK 4870x2, TFC X360 (3x S-Flex F)
    Loop 3: to come
    [DarthBeavis] "I am gonna try to mod one of these into my wife so can get an early warning of when she gets angry . . ."
  25. #25
    Nov 2007
    This is very nice Did you have a piece of mirror at the side?
    Intel Inside
